Tekno SCT410 Thread
#7771
Any of you guys running 1/10 scale ESCs (Flow, R10, Speed Passion, Etc.) with your 550 motors?
Aside from cutting up the battery box, and replacing screws/links, what are you guys doing for weight reduction?
I'm thinking about pulling the trigger on one of these.
#7772
The r10 pro 160 amp is able to run a 4 pole also. Anything that can run the 4 poles can do a 2 pole 550, but the reverse is not true. The HW120 amps and Sp equivalents can power a 2 pole 550 and a 4 pole. My viper vtx10R is only 2 pole 4.5 550 rated. When I get my truck, I hope to use that esc and not buy another. Unless maybe tekin releases a 4 pole capable 1/10th esc. I don't like to buy esc's that don't fit in my b4.
#7774
People been saying that they lighten their trucks up alot they don't handle as well anymore and they go back to stock weight
#7777
Noted. I don't care for the all or nothing powerband of the 4-pole motors (I ran a Tekin 4600 for a while). Awesome power, but no fineness. Maybe I should be looking at a different class... lol
#7778
Its not the motor its the ESC , electric isn't like a fuel based power system . The motor only does what the ESC tells it to , tune the power delivery of the ESC and it will be as smooth as any other motor out there IMO .....
#7779
that is why the tekin guys run the rx8 and limit the current, lol. to help smooth it out. With the 2 poles, if you have a 180 into large jumps, the 4 pole can be nice. But like Acill said, a 2 pole with the torque rotor might be the ticket also.
#7780
Just my opinion though. I'm no expert in 1/10 ESCs, don't even own one LOL.
#7781
I would be cautious using a 1/10 ESC in this truck. They do weigh a fair bit and I know Tekin HIGHLY recommended not using their 1/10 ESC in the Losi SCTE when it came out due to the weight. And the 410 weighs more than the SCTE.
#7783
Ive ran the Novak Pulse coupled to a 4.5t 550 ballistic motor since day one. Havent came off any hotter then the guys running the big 1/8th scale Esc. Ive been running zero timing on the can and 15º from Esc with a 13t pinion. Have no problem keeping up with the 4 poles.
#7785
Anyone wanting their truck to perfom a little differently please take a look at the setup sheet by Pres.
http://www.teknorc.com/tekno5/wp-con..._ilog_SDRC.pdf
Specifically the rear toe, wheel base and battery position. Overall his setup is really good. Only thing to change for low traction conditions would be 7-7-5 or 7-10-5 in the diffs.
17Likes
