Tekno SCT410 Thread
#7922
I am having the same problems with the GensAce 4s packs , and now that they are 80 bucks a pack they are over priced IMO .
These are the best value priced 4s packs IMO , I went to these after the GensAce packs and I like them a lot better ....
http://www.valuehobby.com/power-syst...200mah-4s.html
BTW I also snatched up a couple of those Promatch batteries since the SMC's might not be here for at least another few weeks ......
#7923
I made a bunch of videos with just that, watch this playlist of videos:
SCT410 Build Tips and Info
I've noticed bad nose down only when hitting the jump wrong, or it is an awkward jump transition to begin with. For the most part, my truck (box stock setup) jumps pretty level and is controllable in the air.
For me at least, its not when its to the point that you can't bring it up under power or it causing you to flip when you land.
I personally prefer the truck to jump level under power, and nose down slightly offpower. It should be controllable. Right now when the nose down condition being discussed occurs, its to the point that its not.
#7924
But when it was, it was pretty bad lol. But outside of that, it was really kickbutt everywhere else with some tuning for track conditions. And even with the nose down issue, it was consistent, something that at times my Sc10 4x4 just didn't feel like on jumps.
#7925
Hey head's up fellas the Vant 7200mah 2s lipos are in stock at The Barn Floor here: http://thebarnfloor.com/catalog/prod...6#.UV2-6L-9Kc0
I've heard good things about them as well, I'll report back on performance as soon as mine gets here. Good price point and warranty as well.
#7928
#7929
I received protek's 100c 7000 mah yesterday and they have 5mm bullet connections for their batts. Nice battery I tell ya! Hadn't had a chance to run it yet but will tomorrow. I suggest if you do purchase to order their CHARGING adapter to make things easier on yourself
#7930
they are 4mm 2 plug instead of 4 plug. The IP's are 5mm plugs, but, I did get a set of adapters made cheap from promatch. very nice too.
I have heard they are good.
If you are in need now, these or the IP ones would be fine. You can make or see if promatch can make you an adapter too. That is what they did for me to turn a 5mm connector into a 4mm sized one.
#7934
I had it orginally in a exo, and a prolite. The viper in my opinion beats tekin stuff. I love the viper system, you have to honestly try to make the motor hot. I would recommend it.
#7935
17Likes
. Finally. How are the stock springs?. Hows is this handeling for you guys? I just switched over from a prolite.
