Tekno SCT410 Thread >
Tekno SCT410 Thread
Like Tree17Likes
Tekno SCT410 Thread
Old 10-04-2013 | 01:33 PM
  #15271
ChuckTee's Avatar
Originally Posted by mydudrevo
I didn't care for the stock springs. Greens all around seems to be perfect for me
What kind of track do you run it on? Indoor/outdoor, large/small, smooth high bite/bumpy loose? Been thinking of trying out green all around. Also what pistons do you run? Thanks
ChuckTee is offline
Old 10-04-2013 | 01:42 PM
  #15272
I changed the rear to green, much much better for a hard packed ( pretty rough terrain ) 1/8 scale track.
jason248 is offline
Old 10-04-2013 | 01:44 PM
  #15273
aloksatoor's Avatar
Originally Posted by lala4fire
Is it normal for the front tires to wear out quicker. I noticed that with my new car. I run 7 10 5 diff fluid on a medium grip track. On full throttle the rear end likes to break loose.
Depends on your driving also a lot. But yeah always found the fronts need replacing more often than not on this car. You are running a lot thicker center diff oil than me so it should be lesser wear for you. I run 7 7 5 or if its too loose in rear 7 5 5.
I need to change my base setups now because of the new chassis/weight loss and also the smoother drivetrain. Will do a test day this weekend I guess.
aloksatoor is offline
Old 10-04-2013 | 01:54 PM
  #15274
aloksatoor's Avatar
Originally Posted by rcgod
What springs are the current trucks coming with?
Are you getting another Kevin?
Old 10-05-2013 | 08:56 AM
  #15275
rcgod's Avatar
Smile
No just curious. I'm more than happy with my current car. :-)
Does the new diff case raise the outdrives?
rcgod is offline
Old 10-05-2013 | 09:11 AM
  #15276
fq06's Avatar
Canted for better angle
fq06 is offline
Old 10-05-2013 | 11:02 AM
  #15277
ChuckTee's Avatar
Looks great man. Is that the angled diff case? Or is that a self made modification? Either way it looks good man.
ChuckTee is offline
Old 10-05-2013 | 11:05 AM
  #15278
fq06's Avatar
The new rear diff case, as others have said it didn't need the shims to stay snug either.
Every week a little more Ti finds it's way on it. Lunsford turnbuckles are in the mail.
fq06 is offline
Old 10-05-2013 | 11:11 AM
  #15279
ChuckTee's Avatar
Sounds good, thanks for the info on the shims since I got my new diff case on its way in the mail.
ChuckTee is offline
Old 10-05-2013 | 11:52 AM
  #15280
aloksatoor's Avatar
just the center rear its almost parallel to the chassis now
Old 10-05-2013 | 12:07 PM
  #15281
mydudrevo's Avatar
Hard pack clay high bite 1/8 track the track is very smooth with very large jumps. It also has a washboard section ( very rough section ) and I can go through at full speed and stay perfectly in control. I'm running stock pistons with 45frt and 40rr and 5-5-3 in the diffs. Very dialed. Just started using the jc high flow body but will be going back to the tundra for durability because my brand new jc is already starting so crack in the corners. My tundra bodies have lasted me a good while with no issue
mydudrevo is offline
Old 10-05-2013 | 01:15 PM
  #15282
ChuckTee's Avatar
Well looks like I'm gonna go green, sounds like they are what I'm looking for. Thanks for the info, much appreciated.
ChuckTee is offline
Old 10-05-2013 | 01:23 PM
  #15283
ChuckTee's Avatar
I have a question for you guys. Where are you guys mounting your ESC's on/off switch at on your truck? I am running the side air guards so I have mine on the guard but I am looking around and don't know where else I can put it if I take off the guards. So right now that is preventing me from taking the guards off even just to see the difference in feel without them. I run the RX8g2
ChuckTee is offline
Old 10-05-2013 | 01:33 PM
  #15284
mydudrevo's Avatar
Personally I don't use on/off switches they are just another point of failure so I cut them off and solder the wires together and heat shrink it. Not everyone does this but I knows my who do
Old 10-05-2013 | 02:17 PM
  #15285
fq06's Avatar
Shoegoo'd to the side of the ESC
Also, extension wire against the servo for the transponder
fq06 is offline
