Team Associated B4.2 Thread >
Like Tree4Likes
Old 03-13-2013 | 05:51 AM
  #2761
snowman_evil's Avatar
Originally Posted by mtbboy
Has anyone considered discussing the Associated B4.2 on this thread?
No sorry we only have time to talk about anything/everything except for the B4.2
snowman_evil is offline
Old 03-13-2013 | 06:50 AM
  #2762
Wildcat1971's Avatar
Tech Prophet
There is not much to talk about these days. All of the upgrades come with the car. Mostly people just asking about the chub and ubrace shaving. Maybe if the TLR or durango wheels will fit.
Wildcat1971 is offline
Old 03-13-2013 | 07:08 AM
  #2763
turbo2cam's Avatar
That made me LOL after reading the last 3 pages haha.
My B4.2 is really coming along...I ran my fastest single lap, 5 lap avg, and 10 lap avg last night...So today I'm pretty stoked on the B4.2! I really need to pick up another U-brace and C-hubs and try those out.
turbo2cam is offline
Old 03-13-2013 | 07:55 AM
  #2764
zeakemedia's Avatar
Thanks for the explanation guys. Ordered the servo just now.
zeakemedia is offline
Old 03-13-2013 | 08:04 AM
  #2765
Just wanted to share a few pics of the recently released Yaiba Racing rear hubs for the AE cars. Vertical ballstud mounting for easy roll center adjustment and some extra room between the spring and rear camber link. Pics are on a fresh T4.2, but fitment is the same on the B4.2. More information and complete product line at www.tresrey-usa.com
Jonny5 is offline
Old 03-13-2013 | 08:07 AM
  #2766
Tech Prophet
dont forget you are using the yaiba +1mm shock bushing on the bottom. But yeah, the clearance looks good. The only thing that concerns me is the C hub config. You need to add 2 washers for the C hub height. That would mean 4 washers for the A height. I am not a huge fan of running a large amount of washers and making it more likely to snap a ball stud.
Old 03-13-2013 | 08:11 AM
  #2767
Originally Posted by uncle everett
Use trailing
78/24-26
thanks!!!!
ssshaw07 is offline
Old 03-13-2013 | 08:12 AM
  #2768
After snapping a ballstud in my 22 buggy aluminum hubs I quickly learned after having to buy a second set of expensive hubs that titanium ballstuds are the way to go. Never snapped a titanium ballstud. Might be ok with these hubs.
chevmaro is offline
Old 03-13-2013 | 08:17 AM
  #2769
Running TD cars myself, I've run up to 6mm of shim under the outer steering links and as many as 4mm on both front and rear inner camber link mounts. I understand your concern, but I've never broken a ballstud on them. And the ballstud shim pictured are 3x8mm, providing a wider mounting surface for more stability in that regard.
Ti ballstuds definitely take more abuse than stock ones do. Next on the mod list, just built the truck a few days ago.
Jonny5 is offline
Old 03-13-2013 | 08:39 AM
  #2770
Tech Prophet
oh, I would definitely pick up Ti ball studs for the alum hubs
Old 03-13-2013 | 08:58 AM
  #2771
I'm having trouble distingusing Ti ball studs from some sort of Ti coating.... Looking for Ti ball studs for the Associated B4.1WC, T4.1, and SC10 2wd.
Any help available on here, plz.
shagnat is offline
Old 03-13-2013 | 09:04 AM
  #2772
Matt Trimmings's Avatar
Losi used to make some...AMain has a couple but the long ones are LOSA9947 and they dont have any, the others are 9946,9948,9949. Lunsford also sells them.
Matt Trimmings is offline
Old 03-13-2013 | 09:06 AM
  #2773
Tech Prophet
shaghat. Find the sized you want here.
http://www.lunsfordracing.com/mm5/me...gory_Code=BALL
Old 03-13-2013 | 09:09 AM
  #2774
Tech Prophet
I think these are the actual ones. It does not say 4-40, but I "assume" it is
Old 03-13-2013 | 09:13 AM
  #2775
916bdogg's Avatar
Talking
Built One. Now Building a Second One Mod One 17.5 old Mańs Class ..
916bdogg is offline
