RC10B4.1 FT/WC
Old 03-11-2013 | 05:59 PM
  #28321
5th wheel's Avatar
No matter what I do to this b4.1 its one twitchy buggy and won't run consistent laps it's box stock 17.5
5th wheel is offline
Old 03-11-2013 | 06:09 PM
  #28322
Wildcat1971's Avatar
Tech Prophet
did you add lead?
Wildcat1971 is offline
Old 03-11-2013 | 06:57 PM
  #28323
gogi108's Avatar
go through the car and check bearings , I recently had a diff outdrive bearing go and it would intermittently lock up causing very poor handling . it happened at the same time I installed big bores and was chasing setup for a number of runs till the bearing finally started squeeking . after I changed the bearing the car was imediatly dialed .
gogi108 is offline
Old 03-12-2013 | 04:37 PM
  #28324
5th wheel's Avatar
did you add lead?
No lead
Old 03-12-2013 | 04:48 PM
  #28325
5th wheel's Avatar
Will do. .Some of the fast guys at my track say the b4 is always twitchy that how it is and AE buggys like slop. He could not keep the same lap time. Some laps were fast and some were 2sec or so slower it's just how the b4. 1 is it's not a good buggy for hard pack clay high traction it's better on a soft track. Hell I don'tkknow I am to new. But I like it I have fun with my b4
Old 03-12-2013 | 05:19 PM
  #28326
Tech Prophet
The b4 is fine kn all tracks and gets better then broken in. my tlr22 is way more twitchy and inconsistent
Old 03-12-2013 | 10:53 PM
  #28327
jmc5313's Avatar
Default Chassis flex
My buddy....who is nameless....drives a durango...chopped his frame at some of the webbing...making a super flex chassis...the question i have is...does a more flexable chassis provide better grip on a VERY LOOSE ROUGH track?
jmc5313 is offline
Old 03-13-2013 | 06:33 AM
  #28328
Default FRONT SPINDLES AND GEARING
CAN ANYONE TELL ME THE DIFFRENCE BETWEEN INLINE SPINDLES AND TRAILING SPINDLES? AS IN WHICH ONES WORK BETTER FOR WHAT CONDITION!!
AND WAS WOUNDERING WHAT YA'LL RECOMENDED ON GEARING? I RUN OUT DOOR ITS IN BETWEEN A 1/10 SCALE AND 1/8 TRACK AND RUN A TEKIN RS WITH A ORION 10.5!
THANKS FOR ANY HELP
ssshaw07 is offline
Old 03-13-2013 | 06:50 AM
  #28329
Tech Prophet
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOO
stop yelling at us
Old 03-13-2013 | 12:06 PM
  #28330
Bug Stomper's Avatar
Not trying to be insulting but could be nerves
Bug Stomper is offline
Old 03-13-2013 | 12:24 PM
  #28331
Tech Prophet
No lead
try adding 1/4 oz to each or the rear triangles. Are you running a shorty or a full pack?
Old 03-13-2013 | 12:28 PM
  #28332
Jmuck69's Avatar
If your track is high traction you could use the graphite front arms. This will numb the responsiveness of the steering. After that you could try the graphite top plate and rear U brace. This will also calm everything down. The B4 loves to have slop, makes it more forgiving and takes away the twitchyness.
Slop = Good
Jmuck69 is offline
Old 03-13-2013 | 06:18 PM
  #28333
5th wheel's Avatar
Ok thank you. Full pack
Old 03-13-2013 | 06:21 PM
  #28334
5th wheel's Avatar
Slop = Good
Ok thank you. I have the graphite top plate on already.
Old 03-13-2013 | 06:25 PM
  #28335
5th wheel's Avatar
that maybe be some. But not so much in practice time
