Team Associated B4.2 Thread >
Like Tree4Likes
Old 03-11-2013 | 10:17 PM
  #2686
LOSI123's Avatar
Does anyone know what size (thickness) the AE Cva pin is? I wanted to buy some drill bits and make my own for rebuilds
LOSI123 is offline
Old 03-11-2013 | 10:58 PM
  #2687
Cridd's Avatar
Those last forum few pages with radio, brake, 17.5 discussion was awesome. I can't wait to start playing with my radio. I have a LRP flow I am using drag brake set at 7 blinks, is there anything else on brake side I should look at? Also expo......don't understand when to use and how. Any good web pages on this radio stuff.
Cridd is offline
Old 03-11-2013 | 11:01 PM
  #2688
v6shooter's Avatar
Originally Posted by huzzler
I set the brake on esc to where when I hit the brakes the tires will not lock up. That way if I give it to much brake during a turn the rear end doesn't slide out. It will basically pull the front end down giving me alot of steering. Then just whip around the corner and punch it. Brake is usually set at about 60-75% on Hobbyking 35a esc and tekin 17.5.
+2 my brake don't lock up anywhere on the track so I never lose all momentum. Under braking you don't lose momentum it you will get more steering I don't use the brake that much in a 17.5 race I use it mostly when setting up a turn to pass slow traffic at the same time not to lose momentum. Also diff track has a say so when to use any brake or not
v6shooter is offline
Old 03-11-2013 | 11:03 PM
  #2689
Razathorn's Avatar
I subscribe to the belief that expo anywhere is a blatant fail and will only serve to make you a worse driver. Serious. Linear is how you get the feel for where your throttle and brake are and make it to where you can down side every jump like a boss. If you feel that you need expo, you should gear down, motor down, or turn your EPA down. That's my view.
Razathorn is offline
Old 03-11-2013 | 11:13 PM
  #2690
Razathorn's Avatar
Some tracks it's okay to set your brake so that it doesn't lock up anywhere, but don't be afraid to set it higher when you need to brake harder in one place to go faster. I've ran into several layouts where it was important to brake hard on the face of a jump or other feature that pressed the car into the surface (such as the end of a large bowl corner) where you had to have WAY more brake to take that section fast compared to the brake you could ever use on other sections of the track.
Old 03-12-2013 | 12:13 AM
  #2691
D.Martijn's Avatar
I measured them last weekend because I have to draw my whole car in inventor.
I thought I measured 1.5mm (not 100% sure).
You might want to measure it too
D.Martijn is offline
Old 03-12-2013 | 04:22 AM
  #2692
As long as you're using conventional servos without expo you have greater response close to center and less response farther from center. That's not linear.
Expo was developed to get linear response from rotary servos, and is required for that.
kevinrc is offline
Old 03-12-2013 | 05:36 AM
  #2693
FTW.
Expo is extremely useful. But like everything, use it in moderation.
Manning is offline
Old 03-12-2013 | 06:31 AM
  #2694
Wildcat1971's Avatar
Tech Prophet
Anyone running the 3x1.4 pitons yet? I have some on backorder with amain, just wanted your thoughts.
Wildcat1971 is offline
Old 03-12-2013 | 06:34 AM
  #2695
YankeeFan123's Avatar
Originally Posted by Pete Martinez
Dangerous_toys
When making a purchase, PLEASE make sure that you put the quantity and Item type in the notes section of your Paypal payment. Paypal is [email protected]
You can also find these protectors for the following chassis'
SC10 2x4 Chassis Protectors - Carbon Fiber Vinyl
TLR 22SCT Chassis Protectors - Carbon Fiber Vinyl
SC10 4x4 Chassis Protectors - Carbon Fiber Vinyl
Durango DEX410 Chassis Protectors - Carbon Fiber Vinyl
DEX210 Chassis Protector - Carbon Fiber Vinyl
DESC210R Chassis Protectors - Carbon Fiber Vinyl
B4.1 +8 Chassis Protectors - Carbon Fiber Vinyl
Losi SCTE Chassis Protectors - Carbon Fiber Vinyl
Available in Red or Silver Carbon Fiber too!......Limited supplies!
$9 each
$15 for 2
$28 for 4
Prices include shipping Conus
Just got some new material in and thought I would give it a shot for chassis protectors. These are precut, and are easy to apply to your chassis. It is 3D Carbon Fiber Twill-Weave Vinyl. This unique product is made of UV resistant vinyl that features a carbon textured finish. Unlike those cheap carbon printed patterns, their true 3D texture resembles the genuine look of dry carbon fiber, the weave reflects light the same way as the actual carbon fiber would. They look awesome! Just look at the pics.........
•Permanent acrylic pressure-sensitive self-adhesive
•Stretchable with heat
•Easily cleansed with water
•Resistant to UV, water, dirt, grease, salt, mild acid and oil
•Long lasting
•Easy remove without residue
•OEM Certified Automotive Graphics Vinyl. NOT A 3M DI-NOC product
If anyone wants to send me a chassis for any type of RC vehicle so I can make a template, I would be willing to cut them 2 protectors for free. If anyone is interested, Please message me! Thanks!
I got one from this member, the holes don't line up, the chassis tape doesn't seem long enough and it peels really easily. The only thing I could think of is it wasn't the +8 chassis
YankeeFan123 is offline
Old 03-12-2013 | 06:41 AM
  #2696
BRSracing's Avatar
I have used them the past couple weeks, the car feels really good with them. so far so good. FYI nitrohouse shows them in stock, I got mine from them.
BRSracing is offline
Old 03-12-2013 | 06:55 AM
  #2697
Tech Prophet
how would you compare them to the 1.7 or 1.6's?
Old 03-12-2013 | 07:02 AM
  #2698
Hello,
I used to drive RC Onroad awhile back. Recently bought my son a B4.1 RTR. I'd like to buy for myself a B4.2 but have some questions. Whats a good/great servo, 17.5 motor and esc Novak prefered only because its what I used in the past but I'm open to other brands. Thanks!
NovaCX12 is offline
Old 03-12-2013 | 07:26 AM
  #2699
Originally Posted by NovaCX12
Hello,
Novak Impact 17.5 combo. Savox 1257 servo.
chevmaro is offline
Old 03-12-2013 | 07:33 AM
  #2700
Tech Prophet
Hello,
Solar 770 servo, a viper vtx10 esc and a reedy sonic motor. Novak esc's are behind the times. Replace your kids rtr servo with the solar 770. you will be glad you did. The rtr servo is pretty weak.
