Team Associated B4.2 Thread
#1936
I wonder how accurate Maifields setup is. On the setup sheet it says hes running 10 gram in each rear triangle and 20 next to receiver. In pictures on redrc.net it looks like hes running 5 grams in each rear triangle and 10 grams next to receiver.
#1937
I'm running the 1.6 BB pistons and I keep blowing out bottom e-clips in the rear. The clip is breaking. Guy was telling me that this is because the piston has play between the e-clips and it can get "jarred" in the body causing the e-clip to blow out.
Anyone have the new machined pistons? Are they a better fit? I plan on replacing both rear shafts (they look 100% fine) to be safe and not sure what to do for pistons...New 1.6 kit pistons?...shim them maybe? or wait for the new machined ones to hit the shelf?
#1938
#1939
#1940
#1941
The triangles have the JC 5gram weights in each triangle and he is running two 10gram JC weights next to reciever.
#1942
I'll have more of an explanation when I get home and have the darn thing in my hand lol
EDIT:
Actually I think it was hitting the alum part of the steering rack. at full tilt, the opposite side, slides under the alum "arms" of the steering rack (my RC lingo is limited lol) and on one side, it was catching the edge of the alum "arms".
again my memory sucks, so I'll look at my car tonight to be sure.
#1943
You know, I did notice on my build that the ackerman arm was "sticking" on something when going in one direction but not the other. upon further inspection, the ackerman arm didnt have enough clearance vs ??? (I can't for the life of me remember what exactly it was catching on) I remember I had to hit the top of the ackerman arm with a file (where the rear ballstud hole is) to get 100% of it's range nice and smooth. maybe you have clearance issues with the rack?
EDIT:
EDIT:
#1944
#1945
I had the some problem on front and rear,now I just put fresh clips when I change the oil.
#1947
I just got back from my first night at the track with my 4.2 and to say I am disappointed is an understatement. First of all, I determined the noise I had was the diff barking even when at full tight. I'll take the blame for maybe having it too loose to begin with and causing the issue. However, at the track I only ran 10 minutes and managed to break 3 ball cups from landing normal sized jumps. The first snapped the ball cup portion off which is consistent to what I am used to seeing. However, the last 2 both split entirely in half from tip to tip. I don't know if I got a bad batch or something but I've got some RPM cups on order and will be replacing all of them before my next trip to the track.
#1949
Forgot to mention another issue I had was that the buggy was pulling left during moderate to hard acceleration. It even did this going down the backstretch if I floored it. I checked the alignment and it seemed okay. Not sure if this is normal or not? I'm running a Reedy Sonic 7.5t motor if that helps.
#1950
4Likes
