Team Associated B4.2 Thread >
Like Tree4Likes
Old 03-04-2013 | 06:46 AM
  #2356
Matt Trimmings's Avatar
upgraded shock towers.
Anyway, question. I really hate how the receiver antenna get fed through the chassis. It seems to have some sharp edges that nice the antenna. I was thinking of slotting the antena mount like the 22 to eliminate the goofy current feeding. My only concern is that the antenna might not be snug anymore and will move around or fall out. I know you can bypass the hole and wrap the antenna or ever just coil it up, but i was wondering if anyone has tried to slot it.
use a small piston drill and put a hole about a 1/2 inch from the bottom of the antenna tube. feed the wire through that hole into the tube instead of going into the chassis.
Matt Trimmings is offline
Old 03-04-2013 | 07:22 AM
  #2357
Wildcat1971's Avatar
Tech Prophet
Originally Posted by Bob Barry
wireless receivers...... that's how I roll
http://www.amainhobbies.com/product_...Micro-Receiver
That's the one I use with my 4PL
Yeah, I kinda hope that becomes the norm. I have never liked antennas, lol.
Yeah, I did that last night, but I used my 4-40 bit I use before tapping. Then used an exacto to clean it up. I will probably stick with that for now. I had a few issues getting antenna to feed upwards, but i curled the tip and fed it in. worked much better. I was just debating going a step further and slotting it.
Wildcat1971 is offline
Old 03-04-2013 | 07:30 AM
  #2358
MrGidi123's Avatar
So any of you guys do you feel a difference between the finnisher and the bulldog?
Cheers from switzerland.
MrGidi123 is offline
Old 03-04-2013 | 07:32 AM
  #2359
Cain's Avatar
wireless antenna here too. works well. Hopefully get the range I need for outdoors but, so far so good.
Sat down with my carpet setup on the B4, was pretty happy with how this worked out (using the base B4.1 starting big bore setup):
FRONT
- White 12mm AE Springs
- 1.6 x 2 hole piston
- Losi 35W Oil
REAR
- Grey 12mm AE Springs
- Losi 30W Oil
- Black sway bar
Shorty lipo with 1 spacer up front.
was also a bit surprised how well the V1 Barcodes felt compared to V2s on the carpet, as well as switches in comparison. They provided just enough bite, maybe a hair less than switches but had the rotation that I wanted. V2 Barcodes felt too loose.
Anyway, thought I would post that tid bit to see if there are any other carpet drivers out there with some suggestions. If carpet gets going again I may try the schumacher tires again, but I got this warchest of these types of tires so I figure may just use them up lol.
By the way, anyone got the old school pin type rear wheels or bearing fronts feel free to shoot me a pm as I could be interested in buying them.
Cain is offline
Old 03-04-2013 | 07:38 AM
  #2360
Wild Cherry's Avatar
V2 Bar Codes are not even the same Gold compound as the V1 Bar Code .
V2 are made from the original & harder Gold ...
Wild Cherry is offline
Old 03-04-2013 | 07:44 AM
  #2361
I AM NEW TO AE CARS I JUST PICKED UP A B4.2 I WAS WONDERING WHAT SHAVING DOWN THE REAR U BRACE DOES. BOX STOCK SET UP THE CAR PUSHES REAL BAD I RUN ON A HIGH BITE DAMP INDOOR TRACK. I RUN SLICKS AND A STANDARD LENGHT BATTERY.
SNOPRO74 is offline
Old 03-04-2013 | 07:51 AM
  #2362
Waflet's Avatar
man is it me, or do these new Ion fronts look sick....
Hideeho
Do they make them for 2wd front? I have some for my b44 fronts (out of stock for rears) & love them. I borrowed some rears to try them & found they were extremly consistant. Not the ultimate in lateral grip, but very easy to drive at the limit. Forward bite was very nice also.
Waflet is offline
Old 03-04-2013 | 07:52 AM
  #2363
Page 1 of this thread....post #2
Old 03-04-2013 | 07:53 AM
  #2364
Originally Posted by Waflet
Hideeho
if you have a steady hand you can make them for 2wd. just need a sharp pair of scissors and some glue.
Old 03-04-2013 | 07:56 AM
  #2365
Stealthpilot's Avatar
Racing on a large outdoor track in GA I could not tell a difference running them back to back? I felt a bigger difference changing wings than bodys?
Stealthpilot is offline
Old 03-04-2013 | 08:39 AM
  #2366
Default weight
any body have avg weight for b4 with full size battery??
thanks
motorhead68 is offline
Old 03-04-2013 | 09:01 AM
  #2367
Hideeho
http://rcinsider.com/?p=44527
There ya go
I actually can't wait to try Ions. I haven't gotten the rears yet
Bob Barry is offline
Old 03-04-2013 | 09:04 AM
  #2368
Default U BRACE
THANKS FOR THE QUICK REPLY. BUT WHAT DOES THAT DO TO THE CAR.
SNOPRO74 is offline
Old 03-04-2013 | 09:16 AM
  #2369
To me i use it on higher bite tracks in conjunction with the C hub, it helps to free the rear end up. I use the A hub and a normal brace on outdoor, bumpy tracks. Each person you ask willl have a somewhat different version of what they feel it does...basically you just need to try it out for yourself. Unless you race on a really bumpy, outdoor track...then i wouldnt recommend it.
Old 03-04-2013 | 09:34 AM
  #2370
Tech Prophet
I feel the C hub squares up better and it frees up the rear. But i do not like the shaved brace on outdoor. It is too loose for me. When I run higher bite indoor, I run the shaved brace with the c hubs. But like matt, said, you have to play with it. I am the only one i know that runs the c hub outdoors with the non shaved brace, but i like it. So to each their own.
