Team Associated B4.2 Thread >
Like Tree4Likes
Old 03-04-2013 | 10:03 AM
  #2371
BIGSKI15's Avatar
I think you run at mcculloughs too since i recognize your screen name. I don't have a .2 but it is upgraded all the way to .2 specs. In my buggy, i am running black front, 1.6 pistons, 32.5wt oil and 2mm spacer under the ball stud. For the rear, white springs, 1.6 pistons, 30wt oil and one ball stud washer under the ball stud with a stock ubrace. I am also running 1 degree toe out.
The car is really good there but my driving consistency isn't great. If you are on the right tire i would say it could be your driving style. I know MW ran the shaved u brace there and didn't like it, but Marsh shaves his and obviously does very well.
Originally Posted by SNOPRO74
I AM NEW TO AE CARS I JUST PICKED UP A B4.2 I WAS WONDERING WHAT SHAVING DOWN THE REAR U BRACE DOES. BOX STOCK SET UP THE CAR PUSHES REAL BAD I RUN ON A HIGH BITE DAMP INDOOR TRACK. I RUN SLICKS AND A STANDARD LENGHT BATTERY.
BIGSKI15 is offline
Old 03-04-2013 | 10:16 AM
  #2372
YES I RUN AT MCCULLOUGHS I WAS RUNNING A 22 BUT WANTED TO TRY A B4.2 I DIDNT KNOW WHAT TO EXPECT . IT'S BOX STOCK SET UP WITH HOT BODY'S PINK SLICKS FIRST TIME OUT IT WOULD'NT EVEN TURN I PLAYED WITH IT A LITTLE IN BETWEEN HEATS AND HAD SOME HELP FROM OTHER GUYS ON DIFFERENT SET UPS BUT ITS STILL NOT RIGHT
SNOPRO74 is offline
Old 03-04-2013 | 10:18 AM
  #2373
Matt Trimmings's Avatar
Is your keyboard broken?
Matt Trimmings is offline
Old 03-04-2013 | 10:30 AM
  #2374
Cain's Avatar
Tech Legend
Nah ... He just wants to make sure you "hear" him .
Cain is offline
  #2375
Razathorn's Avatar
For me, on our track, I can get the almost the same feel from the c hub or a hub. This is the fun of low to medium bite.
The thing with the c hub is it allows for a much lower roll center setting, so if you find yourself running the stiffer springs like white or grey in the rear of your car, then you can use the c hubs to get some of your chassis roll back for infield traction. For our track, greens in the rear work best, so we actually have a lot of chassis roll readily available and C hubs need to be run with zero washers shaved to even work right. Then you're left with nowhere to go if you want a higher roll center, so we tend to stick with As on almost everything here. Those who go out of town will tell you that Cs work very well on other tracks, so it is seriously just a tuning option, no one option works better everywhere.
Razathorn is offline
Old 03-04-2013 | 10:40 AM
  #2376
you aren't kidding about stuff feeling the same with the low / med bite LOL. If the tires aren't right, nothing really feels different.
I decided to try extremes yesterday... started with C hub / shaved +1mm and then went straight to A hub / std +2mm.
The first setup (C hub) would be free going into the turn and as you rotate through, then when you hit the gas it locks in and you have good bite.
The second setup (A hub) was very locked in going into the turns and through the middle, but if you jumped on the gas, it would wash out.
I hope that helps illustrate the differences (at least to me). Remember this is extreme switches and every track will feel different. Best thing I can tell you is get out there and compare them back to back.
Bob Barry is offline
Old 03-04-2013 | 10:49 AM
  #2377
Wild Cherry's Avatar
Tech Legend
C-hub makes more grip
comparing to the A & B hub
Wild Cherry is offline
Old 03-04-2013 | 10:52 AM
  #2378
no, it makes different grip
I felt the C has more grip on power exiting but the A has more low speed going into the turn.
I TYPE LOUDER! I AM RIGHT! RAAAAAWWWWWWWWRRRRRRRR
Old 03-04-2013 | 10:57 AM
  #2379
MRCCC's Avatar
Hey guys is a ball bearing diff supposed to have any slipping at all under heavy torque or should there be no slip at all...I just rebuilt mine and if I try to turn both outdrives while holding the gear it starts to slip after strong torque....Did i *%$&* up the rebuild?
MRCCC is offline
Old 03-04-2013 | 11:00 AM
  #2380
bds81175's Avatar
Moderator
Bingo!!! AND I CAN TYPE EVEN LOUDER!!!!!
bds81175 is offline
Old 03-04-2013 | 11:12 AM
  #2381
Razathorn's Avatar
OMG Hartson used A hubs on his 4.2 and won at Motorama.
http://www.teamassociated.com/pdf/ca...n_Motorama.pdf
A hubs are the new C hubs!!111 QUICK, everybody switch back to As now. Come on sheeple! It has to be better!
It's a tuning option. Don't be fooled. Different tracks like different stuff.
Old 03-04-2013 | 11:15 AM
  #2382
mingoglia's Avatar
No, it should never slip. If you are getting it to slip either it's worn, not adjusted, or your hands are a lot tougher than mine. I try to make my slip to the point where it feels like my hands are going to bleed holding on to the spur. Regardless though, your clutch should ALWAYS slip before your diff.
mingoglia is offline
Old 03-04-2013 | 11:53 AM
  #2383
ROFL.... His setup gave me the idea to test the extreme swing. I still think I prefer C / 1 washer but I was trying new stuff
Old 03-04-2013 | 12:00 PM
  #2384
Tech Legend
sorry its more traction ...
Use the A or B for freeing the car up ....
  #2385
Venom1836's Avatar
I am having trouble with my battery sliding forward.
Would getting the JC Monroe strap provide more surface area and hold the batt. down better?
Venom1836 is offline
