Arrow Racing GTR .21 Engine Thread >
Old 01-21-2013 | 09:46 AM
  #1096
Originally Posted by bigjayjay1
What version were you running on the arrow, five port??
I was running th V3.Havent had the chance to try the 5 port out yet.
xxxntwv is offline
Old 01-23-2013 | 05:28 AM
  #1097
I went up to the Midwest CRCRC on Thursday. The Arrow ran excellent and I was using the 2013 pipe. After trying a few different pipes, the 2013 to me was the best. Offers a totally different powerband. This track however was pretty fast and thursday night I took the engine off in favor for my Nitrotec because I'm not use to that kind of power and I was starting to over drive the car. Definately not the place or time to experiment. Now it's time to learn it.
Greg B is offline
Old 01-23-2013 | 02:59 PM
  #1098
bigjayjay1's Avatar
Greg what version five port
bigjayjay1 is offline
Old 01-23-2013 | 03:03 PM
  #1099
No, just the 3-port. I would have never had the time to break in a new 5 port and get it ready. It's so cold here , I been farting snow flakes for 3 days now.
Greg B is offline
Old 01-24-2013 | 01:56 AM
  #1100
any takers on the front bearing leaking i posted on the previous page?
picko990 is offline
Old 01-24-2013 | 02:01 AM
  #1101
If the engine is running rich the front bearing will leak,If its tuned correctly and still leaking its time for a new bearing.front bearings are cheap and easy to replace.
xxxntwv is offline
Old 01-25-2013 | 11:10 AM
  #1102
ark champ's Avatar
I got my engine and pipe a couple of days ago. Can't wait to fire it up, it looks sweet. Has any one ran it yet that can let me know what to expect?
ark champ is offline
Old 01-28-2013 | 11:25 PM
  #1103
thanks for the info. after cleaning, inspecting then running again it appears to be weeping only. tune was fine.
picko990 is offline
Old 02-10-2013 | 08:31 AM
  #1104
Danny Teh's Avatar
NEW GTR Plus
I ran the new engine and I find it more powerful and most importantly the fuel efficiency is a double ++
It comes with a Low CG heatsink sits lower....very solid.....still uses a P3 plug.....tuning for low and mid speed needle as mentioned in previous posting but HSN a lot leaner and still sounds reasonable.........
Attached Thumbnails Arrow Racing GTR .21 Engine Thread-2013-02-07-14.10.42.jpg   Arrow Racing GTR .21 Engine Thread-2013-02-07-14.10.07.jpg   Arrow Racing GTR .21 Engine Thread-2013-02-07-14.11.07.jpg   Arrow Racing GTR .21 Engine Thread-2013-02-07-14.56.13.jpg
Danny Teh is offline
Old 02-10-2013 | 11:04 AM
  #1105
ark champ's Avatar
Originally Posted by Danny Teh
NEW GTR Plus
What are the needle settings? Still in break in on mine, taking it slow. When you say the HSN is a lot leaner, how much? Can you give the needle settings you are running at and what temp and millage you are getting? Thanks.
Old 02-11-2013 | 10:42 AM
  #1106
VPProUSA's Avatar
Mid - 2 turn out from flush at 2 oclock
Low - 1 turn in from flush
Top - depends on fuel,pipe,and manifold used
VPProUSA is offline
Old 02-11-2013 | 06:57 PM
  #1107
ark champ's Avatar
Thanks Gene. Motor feels real good so far and haven't turned a needle more than 1-2 hours from factory. I'm guessing this motor will like to run like the others at around 240-260. Turning it loose this weekend at the pro series.
Old 02-11-2013 | 07:00 PM
  #1108
VPProUSA's Avatar
Yes, I run mine around 275' when empty and broken in.
VPProUSA is offline
Old 02-11-2013 | 08:06 PM
  #1109
Mark Erce's Avatar
so with the mid setting...
1. set it flush
2. richen it 2 full revolutions
3. set it at the 2 oclock position
is this correct? or do you mean 2hrs? just seems like alot of turning unless the needles are way off from the factory
Mark Erce is offline
Old 02-11-2013 | 08:07 PM
  #1110
VPProUSA's Avatar
yes
It should be at 2 oclock from the factory. Just make sure it is 2 turns out from flush.
VPProUSA is offline
