Tekno RC EB48 Thread >
Like Tree2Likes
Old 01-21-2013 | 03:13 PM
  #4411
Originally Posted by GenX69
I broke my wheels with spokes on the eb48 so put some black dishes on I had at home. Suddenly the entire drivetrain was seized/frozen. Turns out the wheel sat on the hub too far and was pressed firmly against the hub carriers. This was a new one for me but the veterans told me it used to a common issue. Anyone have this issue? Any fixes? I know I can put a washer/shim though I am not certain what size would be ideal as I've yet to measure everything. I plan to order new wheels and tires but worry I will have the same issue with the new wheels.
What wheels are you using?
Pro-Line and AKA wheels have both worked fine for me.
-Kane
Kane-o is offline
Old 01-21-2013 | 03:40 PM
  #4412
BashemSmashem's Avatar
-Kane
I have tried Ofna , Losi , AKA , HotBodies , AE , Proline , and some JQ wheels and all fit with no problems ....
BashemSmashem is offline
Old 01-21-2013 | 05:33 PM
  #4413
GenX69's Avatar
Will take a look when I get home and let you know. My guess is HPI but I'm unsure.
GenX69 is offline
Old 01-21-2013 | 08:39 PM
  #4414
Originally Posted by Outtacontrol58
Hey I drive the buggy this weekend and it was great!!! I'm running on a med size hard packed outdoor clay track. 7-7-3 and 40-35 front to back. What can I do to get more rear tracking. The thing seems so agile and confident in the air! Thanks
I'm no expert but I can give you some of my thoughts.
I'm running the stock diff fluids---7-5-3 seems to work really well for the track i'm presently running on.
Easier options would be to go down a little in rear shock fluid--try 30 vs 35, this will make the shock more plush/soft & therefore should help . You can also try moving the shock location--ie move the top of the shock in one hole or two--this can aid in providing a little more traction.
JASF4I is offline
Old 01-22-2013 | 03:06 AM
  #4415
Desert Runner's Avatar
Originally Posted by kevinpratt823
I would love to try it out, I'm sure it is a whole other element. What do you use for tires? We have sand here(New England), but probably nothing like what you have. I raced motocross for years, and I am local to Southwick which is considered the only real sand track on the AMA pro circuit, and it definitely does take a different technique to go fast there. I will have to find some of your videos now..........
i'm using Panther's Geko tires. too bad it's now rare to be found . not sure if you could find any if there's some left here or there because it's no longer available at major online stores.
it gives the best in between for on and off roading.
recently i bought the proline badlands, but if you're looking for tires simillar to the Panther's Geko i would recommanede the HB Proto.
Desert Runner is offline
Old 01-22-2013 | 03:15 AM
  #4416
Originally Posted by Cain
lol. And of course I can't see it through photobucket . Anyway you can attach the pics to your post using rctech's attachment feature. If not no worries
i just uploaded the pic to my album here in the forum. not sure how to post it though.
if this link works please let me know. if not advise how to attach my albums pic here. sorry for the delay.
http://www.rctech.net/forum/members/...ock-spure.html
Old 01-22-2013 | 07:35 AM
  #4417
Cain's Avatar
showed up. looking forward to hearing how well it fits for you.
Cain is offline
Old 01-22-2013 | 10:29 AM
  #4418
Slotmachine's Avatar
A smaller rear sway-bar will help also, and they are cheap enough to get all of them from Tekno.
Slotmachine is offline
Old 01-22-2013 | 10:55 AM
  #4419
I just wanted to share some things I learned about this buggy this weekend. I was racing in the CRCRC Midwest championship this last weekend and the previous. The first weekend was electric and the track was like a giant fly paper. My car seemed to love it. The second weekend was nitro where things got crazy. The track dried out completely and was way looser than I had ever seen. I was lost. I kept making changes only to still seem to have no traction. Then before the mains, I tried something just for the heck of it. I sanded down the hubs so that I could glue some lead weights to them. Wow did this make a difference. I only had 1/4 ounce on each front spindle, and 1/2 ounce on each rear hub. This seemed to make all the difference in the world. Has anyone else experimented with this? BTW I just got the car a month or so ago, and have not ever run it outdoors so I am wondering if traction is always an issue with this car?
t-man is offline
Old 01-22-2013 | 11:08 AM
  #4420
I run on low grip, bumpy outdoor tracks and traction is never an issue.
MX304 is offline
Old 01-22-2013 | 12:36 PM
  #4421
I found dropping to 35 front 30 rear oils and 5 5 1 diff oils really locked the back in for me, at least it did this weekend and previous to that I was running 5 7 3. I'm also running minimum antisquat, and the shocks layed over in the back- flip flopped stock sway bars (smaller in rear). Setup for max rear toe.
Everything else stock except white durango rear springs (harder).
Antimullet is offline
Old 01-22-2013 | 12:54 PM
  #4422
Cain's Avatar
you could also start by dropping the middle fluid first and go from there. For loose stuff usually go down in the front and middle diff oil weights on other vehicles, could be similar here.
Cain is offline
Old 01-22-2013 | 01:32 PM
  #4423
GenX69's Avatar
I changed the shock oil for the first time on the front shocks. I think I've put 12 or so packs through the car so far so felt it was time. Plus I wanted to check to make sure there were no issues. The caps were dirty on the inside and the bladders had dirt on top of them. I fully expected the oil to be dirty as well. However, the oil was still clean. The dirt must have gotten in via the bleeder hole on the caps and then collected above the bladders.
There is a pin-sized hole on the inside of the caps. It is right in the center. Does that serve a purpose?
GenX69 is offline
Old 01-22-2013 | 05:54 PM
  #4424
teknorc's Avatar
It's a vent to keep the shock more consistent. You can put some glue in there to cover it up and it will act like a normal cap. The vents make it easier to get zero rebound in the shocks and make them more consistent but not necessarily 'better' for every track condition though. A 'bleeder' cap (just the side hole) will have more rebound since the air above the bladder doesn't have anywhere to go.
teknorc is offline
Old 01-22-2013 | 07:10 PM
  #4425
Whats the general consensus on how often to change fluid in the diffs?
and
Can you just change the fluids and gasket or do you have to replace o-ring seals also?
RC Geezer is offline
