Tekno RC EB48 Thread
#4411
I broke my wheels with spokes on the eb48 so put some black dishes on I had at home. Suddenly the entire drivetrain was seized/frozen. Turns out the wheel sat on the hub too far and was pressed firmly against the hub carriers. This was a new one for me but the veterans told me it used to a common issue. Anyone have this issue? Any fixes? I know I can put a washer/shim though I am not certain what size would be ideal as I've yet to measure everything. I plan to order new wheels and tires but worry I will have the same issue with the new wheels.
Pro-Line and AKA wheels have both worked fine for me.
-Kane
#4412
#4414
I'm running the stock diff fluids---7-5-3 seems to work really well for the track i'm presently running on.
Easier options would be to go down a little in rear shock fluid--try 30 vs 35, this will make the shock more plush/soft & therefore should help . You can also try moving the shock location--ie move the top of the shock in one hole or two--this can aid in providing a little more traction.
#4415
I would love to try it out, I'm sure it is a whole other element. What do you use for tires? We have sand here(New England), but probably nothing like what you have. I raced motocross for years, and I am local to Southwick which is considered the only real sand track on the AMA pro circuit, and it definitely does take a different technique to go fast there. I will have to find some of your videos now..........
it gives the best in between for on and off roading.
recently i bought the proline badlands, but if you're looking for tires simillar to the Panther's Geko i would recommanede the HB Proto.
#4416
if this link works please let me know. if not advise how to attach my albums pic here. sorry for the delay.
http://www.rctech.net/forum/members/...ock-spure.html
#4417
i just uploaded the pic to my album here in the forum. not sure how to post it though.
#4418
A smaller rear sway-bar will help also, and they are cheap enough to get all of them from Tekno.
#4419
I just wanted to share some things I learned about this buggy this weekend. I was racing in the CRCRC Midwest championship this last weekend and the previous. The first weekend was electric and the track was like a giant fly paper. My car seemed to love it. The second weekend was nitro where things got crazy. The track dried out completely and was way looser than I had ever seen. I was lost. I kept making changes only to still seem to have no traction. Then before the mains, I tried something just for the heck of it. I sanded down the hubs so that I could glue some lead weights to them. Wow did this make a difference. I only had 1/4 ounce on each front spindle, and 1/2 ounce on each rear hub. This seemed to make all the difference in the world. Has anyone else experimented with this? BTW I just got the car a month or so ago, and have not ever run it outdoors so I am wondering if traction is always an issue with this car?
#4420
#4421
Everything else stock except white durango rear springs (harder).
#4422
you could also start by dropping the middle fluid first and go from there. For loose stuff usually go down in the front and middle diff oil weights on other vehicles, could be similar here.
#4423
I changed the shock oil for the first time on the front shocks. I think I've put 12 or so packs through the car so far so felt it was time. Plus I wanted to check to make sure there were no issues. The caps were dirty on the inside and the bladders had dirt on top of them. I fully expected the oil to be dirty as well. However, the oil was still clean. The dirt must have gotten in via the bleeder hole on the caps and then collected above the bladders.
There is a pin-sized hole on the inside of the caps. It is right in the center. Does that serve a purpose?
#4424
2Likes
