The AE FActory Team B44.2 Thread
#740
would this screw kit be any good for 44.2?:
http://www.amainhobbies.com/product_...teel-Screw-Kit
#741
I'll never buy RC Screwz again. The heads break clear off and they strip just as easy as the kit screws.
#742
Best Regards.
#743
those who had the .1 and now the .2
Notice any push with the car being +8?
I run the .1 with NO ballast weight, gives better rotation, IMO.
Pro's obviously win with it but for the rest of us?
Kody N. rocked it at Spektrum!
#744
Started my build last night and things were just not feeling right!i am used to 2wd trannies that spin very freely. Some guys at local track say a 4wd feels tighter but mine feels to tight. Should you use the set screws in all cvas?i had two that with the screws in they were binding others smoothe.
Directions don't show installing set screws but they come in the bag.
Any help will be greatly appreciated!
My diffs feel. Good, I used the 6&3 spacers but main cvas still feel tight where it comes out of gear box..
#745
diff/tranny will break in, tight now will be smooth after a pack or two.
Don't use the supplied set screw when building CVA's they're not needed. The retainer ring replaces them. A drop of CA to hold them (retainer ring) in place is also a good idea (IIRC it's recommended in the manual as well)
#746
My problem is in the front,everything feels good till I snap the gear covers ,the the binding starts,not bad but tight,install screws and it becomes tighter,should I try and space it 5&3? I tried this first but there was about 1/16-1/8. " of play,is this ok or will I burn out gears?
#747
Thanks Racer!
#748
If it feels too tight and like it's not exactly spinning free on the CVA coming out of the gearbox, check to be certain you cut off the flashing and smoothed out the back of the drive pinion gear as shown on page 5 step 2 of the manual.
#749
I took a little of with an exacto,how much is there?
#750
