SC10 4x4 Thread
No, it's not the radio gear. My servo (hitec 7940) is fresh and has no slop or centering issues. My Ko propo Helios is working properly as well, since I run 4 other classes and none of those cars have the same problem. Something is not right on the truck but I'm still trying to find what it is.
Pro Street
Check under your chassis , see if you installed the correct screws (#89454) to mount the ft gear box . If you use too long a screw ,will block the steering rack from moving all the way .
Best bet give it a try.
what do you mean by hot? Do you have an actual temperature measurement?
here is a quote from someone I trust on a breakdown of the 8mm mod in his opinion:
The 8mm mod plants the rear and and reduces traction rolling.
Now, how you want to go about using this to your advantage is a whole different story. The reason behind the mod is that keeping the angle of the upper link the same by raising both ends equally lowers the roll center, so in that regard it makes sense that people are doing this mod to try and make the rear end more predictable. That is as simple as it gets.
Now for some reasons why you shouldn't do the 8mm mod automatically. The higher the traction, the less need there is (from the standpoint of 'planting' the rear end) to run the 8mm mod. If you are perfectly content with the handling of your car, but are strictly looking to reduce traction rolling, I would look elsewhere (say, lowering ride height a millimeter or two and going to a stiffer sway bar). At the ROAR Nats, Maifield didn't run the 8mm mod because the track had enough traction and he needed the car to transition very quickly from left to right in all the high speed chicanes and flowing corners. There is a point at which lowering the roll center too far creates a lazy feeling car that is slow to transition, so while it would have given him more rear traction, the car wouldn't have transitioned as quickly. If the track was slower with more 180's and fewer switchbacks, I'm willing to bet he would have been running the 8mm mod.
I use it.
I ran it on a high to medium bite, traction rolled everywhere. I took it off for the exact same track, layout, setup, everything. Stopped traction rolling, and TQ'd every qual.
I put it back on in my local basher track and the feeling is amazing with it.
The mod is for loose surface, dear god why can't we get past this.
The 8mm mod plants you 'too much' in highbite. You just need to try it and see for yourselves.
This is reality, not Wild Choke theology.
The 8mm mod plants you 'too much' in highbite. You just need to try it and see for yourselves.This is reality, not Wild Choke theology.
Thanks Cain that they will clarified it for me thank you
Metrics I also had made my own center diff and then it later upgraded to be to do it I noticed a fair difference between the two in the regular at least on acceleration but offered sorry's and felt about the same the biggest advantage I would say is the added bearing that you provide with the kit
Cain , confused ?
Ha ! Ha !
Its really easy to make mistakes judging a set-up change ..
You will have to trust me on this one ...
Scotty's Show Down Tour
Have a bunch of team mates in Texas right now , even heard one my best Bro's Greg-Ory is there !
BK is building a new Sc10 for Greg as I post ....
Awesome news for me to hear ....
Ha ! Ha !
I use it.
As you can see OP or anyone else, this is the dilemma about the 8mm mod as there are different opinions on what it does. I tried it, and I differ on opinion on what I saw (more traction on the rear).
5Likes
