RC10B4.1 FT/WC
Ran some off-road indoor carpet today. Both b4's were absolutely great with the Schumacher mini pins.here is my buddy running a few laps
| + YouTube Video | |
what are you guys using for battery foams when you run shorty packs? Does the short course foam work well? 1 in front 1 in the rear? Right now I have just a bunch of foams in there but I would like to make it 1 front 1 rear if possible to avoid me moving one by accident
Ok heading to the track tomorrow after about a two week break. Last time at the track I was having issue's with the rear end being very loose, after landing jumps and trying to get on the throttle I was always sliding out (the rear)...... What are some things I can do to eliminate this, besides the obvious throttle control, tires etc?
See above, i run on a indoor med. bite track with a mixture of clay and dirt.
Im sure in the next month this will be discussed a lot. Im going to guess you will run the same springs as you would run if you are running the big bore springs that are on your v2's. As far as oil that depends on what pistons you are running.
