RC10B4.1 FT/WC
Old 09-07-2012 | 08:48 AM
  #19996
Wildcat1971's Avatar
Tech Prophet
ok, for those switching to hex up front, I found some low profile 8/32 lock nuts at ace for 20 cents each. Here is a pic. the one on the right was from ace.
By lhelmrich at 2012-09-05
here you go. I found it for you
Wildcat1971 is offline
Old 09-07-2012 | 08:56 AM
  #19997
Short nuts like the ones on the B44? You can get the blue anodized ones from AE, but my friends and I run short and tall castle nuts from McMaster. Similar lock nuts should be available at any store specializing in fasteners, probably for less than Ace.
EricJ is offline
Old 09-07-2012 | 09:28 AM
  #19998
rb-digi's Avatar
Originally Posted by PFKAOG
How will you tighten the nut without the axle spinning without the pin?
it tightend up .i just snugged it to test the bearings and free spin cause i dont have the right axle nuts yet,i didnt get too crazy with the set screw on the clamping hex i just tightend it up and then tightend the wheel ..but what your sayin makes scense ..i hadnt thought about that.thnks
rb-digi is offline
Old 09-07-2012 | 09:40 AM
  #19999
rb-digi's Avatar
Originally Posted by EricJ
It keeps your axle from escaping out the back should it get loose. Also, pitch the roll pin and use an old CVA pin, which is a lot easier to remove and is probably stronger.
thanks alot ..ace is right around the corner.
rb-digi is offline
Old 09-07-2012 | 10:18 AM
  #20000
Eli's Avatar
Eli
JC has some nice low pro front wheel nuts that are intended for the b44 but they will work on the b4 as well
Eli is offline
Old 09-07-2012 | 10:20 AM
  #20001
Tech Prophet
yeah, but a little pricy. I prefer 80 cents at ace to almost $14
http://www.amainhobbies.com/product_...Nut-Set-Blue-4
Old 09-07-2012 | 10:38 AM
  #20002
Originally Posted by rb-digi
i got a dumb question..when converting to hex's on the front end of the b4.1 and using clamping style hexs (avid in my case) is there any reason to run a roll pin thru the axle? like there is no drive to make them slip and it seems to be attached well with out it..i didnt see any mention of them in the required parts list for conversion..thnks in advance..oh and is there any options when it comes to a low profile front axle nut.all new tires and hexs ready to go and none of my lhs's have the associated ASC9880,,any thing else or another brands nut work dialed?
I get mine from here:
http://www.fastener-express.com/nylo...-aluminum.aspx
ufoDziner is offline
Old 09-07-2012 | 10:45 AM
  #20003
How about these from mcmaster.com (search the part numbers)?
90633A009 - Zinc-plated nylon-insert lock nuts - $0.023 each.
90101A009 - Stainless nylon-insert lock nuts - $0.0852 each.
We usually run the much more expensive "expanding" lock nuts...
94830A490 - Cadmium-plated - $0.442 each.
94140A490 - Stainless - $1.276 each (pricey).
In all cases, I've started using loctite pretty regularly, especially on the thin front nuts. Rears can go a few race days between re-application, but fronts have so little to grab on, it's just safer to use more.
EricJ is offline
Old 09-07-2012 | 10:50 AM
  #20004
B.A. Racer's Avatar
the jc nuts are serrated though..so they will last a lot longer than locknuts...yes pricey, but def. last a very long time
B.A. Racer is offline
Old 09-07-2012 | 10:52 AM
  #20005
B.A. Racer's Avatar
why use locktite? when the nut even feels just a little loose..replace it...or just buy serrated.
Old 09-07-2012 | 11:00 AM
  #20006
Originally Posted by 3srcracing
So I am trying that anodizing thing and it's not working. I got one to work but now they are just going in the same color they came out (dark gray) any idea what I am doing wrong?
I have the negative wire on the turnbuckle positive in the simple green (no dolited). I have it for I have 81Volts to get the shiny gold. I even checked it with the volt meter to make sure its 81 volts and it is. I wrap it on the tip of the turnbuckle put it in right before the wire touches leave until bubbles stop or 35 seconds. And then pull out, but nothing happens?
What am I doing wrong?
Check this -> http://www.rcten.com/threads/how-to-...nbuckles.1389/
Sylvain is offline
Old 09-07-2012 | 11:04 AM
  #20007
What are the benefits of using 12mm hex in front?
I understand for the rear wheels but not for the front....
Sylvain is offline
Old 09-07-2012 | 11:25 AM
  #20008
Atomicsickness's Avatar
Bearings are not retained in the rim is the biggest advantage for me. I hat having to pop the bearings out of the rim every time I take them off.
Atomicsickness is offline
Old 09-07-2012 | 11:31 AM
  #20009
ilanstylz's Avatar
You know I never thought of that but it makes perfect sense. I can't remember how many times I've change out my front rims at home or the track and had a bearing or two get away from me only to go rolling all over the place and me chasing after it. Not a good sight for a big guy to be crawling on the ground looking under pit tables lol.....
ilanstylz is offline
Old 09-07-2012 | 11:34 AM
  #20010
In my case, this is not a big advantage plus I have a bunch of front wheels
Sylvain is offline
