Like Tree5Likes
SC10 4x4 Thread
Old 09-06-2012 | 03:30 PM
  #29356
Hobby People have supported me for 3 years. Batteries are 2 years old and still take more than they're rated for.
If you're a C rating freakzoid
2S 6500 70c Stick
If you're sane (personally own 2 two year old ones, that like I said... amazing)
2S 5000 35c Stick
Saddles aren't too cheap (again, I own two sets)
2S 5000 50c Saddle
No, I'm not sponsored or give a poop about what you get, but these have done so well and the 20 other brother batteries I know about have never once had an issue. The prices aren't insane like Reedy and the other guys either. Just a suggestion!
SC Shaun is offline
Old 09-06-2012 | 03:41 PM
  #29357
JEFFs SC10's Avatar
$117 for saddles
JEFFs SC10 is offline
Old 09-06-2012 | 03:50 PM
  #29358
ryanpatrickgore's Avatar
reedy saddles are cheaper.
+1 on promatch im gonna try a set of those next as well
ryanpatrickgore is offline
Old 09-06-2012 | 03:57 PM
  #29359
mHOUPS's Avatar
Originally Posted by AErckidd
My truck has been making a lot of clicking noises. I notice a clicking noise when I get on the gas hard out of a corner, and also when going into a corner hard on the brakes. I think coming out of the corners it sounds like the diff, needing to be shimmed. And going into the corner it sounds like the clicker or the belt slipping. Could this be correct? And what could I do to fix these problems? I think my clicker nut is completely tightened down. And I just put a brand new belt on it. It got better but still made the noise.
Look at the clicker first! Make sure there are no rocks in there, if no rocks tighten the nut. Mine was doing the same thing and a retightening of the nut did the trick. Some guys glue the nut on and even add a 2nd nut to ensure it stays locked/tight.
Start with the easiest first, you should be bale to spin the wheels and hear where the noise is coming from.
mHOUPS is offline
Old 09-06-2012 | 04:03 PM
  #29360
MD's Avatar
MD
Try HobbyKing for reasonable saddles.
MD is offline
Old 09-06-2012 | 04:05 PM
  #29361
mHOUPS's Avatar
You can use these HERE
Or these HERE
Both are way less expensive, you want the highest C rating you can get for these 4x4 trucks, low c ratings = puffy packs.
mHOUPS is offline
Old 09-06-2012 | 04:07 PM
  #29362
MD's Avatar
MD
Here are some reasonably priced batteries with a high "C" rating.
http://www.hobbypartz.com/gensace65c.html
MD is offline
Old 09-06-2012 | 04:39 PM
  #29363
johnbugman's Avatar
Default batterys
I have been using protek saddles and they come with a decent warranty. They are 70c rated and keep up with a tenshock 550 4 pole motor.
johnbugman is offline
Old 09-06-2012 | 04:45 PM
  #29364
Cain's Avatar
those are all stick packs. I am assuming the original discussion was concerning saddles.
Cain is offline
Old 09-06-2012 | 04:53 PM
  #29365
MD's Avatar
MD
I thought someone in an earlier post had a picture of a thunder power stick pack. As someone said, Hobby King has some good saddle packs.
MD is offline
Old 09-06-2012 | 04:58 PM
  #29366
Wildcat1971's Avatar
Tech Prophet
well, one of the faster guys at my track runs the turnigy, he has about 8 of them. and 8 of them are puffed. does not seem to slow him down, but meh, I dont really want preger packs.
Wildcat1971 is offline
Old 09-06-2012 | 05:02 PM
  #29367
Jake S's Avatar
if going for nano's checkout the a-spec...
http://www.hobbyking.com/hobbyking/s...ddle_Pack.html
i have had great luck with smc packs also... but they are out of stock.
http://www.smc-racing.net/index.php?...&product_id=69
Jake S is offline
Old 09-06-2012 | 05:10 PM
  #29368
Tech Prophet
No US stock yet on the A Specs
Old 09-06-2012 | 05:24 PM
  #29369
Jtipsy's Avatar
The smc packs are awesome had some for 2 years going on now and never puffed always balance have about 90 charges on them. Use only in winter time. Other wise they are storage charged and put in the freezer i cycle them once every other month during the summer just to peak them out and run them down and charge them back to 3.7 each and back in the freezer they go.
Use good plugs with them also i did have the ones that had the baskets on them and those connectors seem to wear out real fast. The solid ones from castle or tq racing products work wonders.
Jtipsy is offline
  #29370
MD's Avatar
MD
I'm sorry to hear that. I just bought some. I have a Turnigy stick pack that has been good, but thanks for the warning. I'll watch them carefully when I charge them.
MD is offline
