Like Tree5Likes
SC10 4x4 Thread
Old 09-10-2012 | 09:53 AM
  #29506
Originally Posted by BorackBasher
mesh isnt the issue.. it will drive smooth as butter until i hit something.. not hard either where it shouldnt strip the spur.. i let jimmy barnett drive the truck yesterday and it was super quite until he wall tap the wall.. then all of sudden bam! sounded like a losi.. crunchy to the max
Sounds to me like something in your drive train is binding thru travel or shock when you land hard or hit something, check travel thru the car for a axle or bearing binding, this will lock up and strip a spur in a split second, also check your chassis bolts, if loose the rear end can flex left to right, just a thought, have you checked the bearing behind the slipper, no movement in and out with the slipper assembly, could bind up under an impact or maybe twist abit?
RossNZ is offline
Old 09-10-2012 | 10:02 AM
  #29507
BorackBasher's Avatar
the bearing in the transmission case that the top shaft goes through? i will double check that today when i go to the track.. the front chassis brace screw is bent.. it keeps on bending and i finally just left it in... there is some flex even with the chassis brace.. is that my issue right there?
BorackBasher is offline
Old 09-10-2012 | 10:05 AM
  #29508
Cain's Avatar
Tech Legend
Heck, I wonder if that flex you get could be causing the belt to bind up possibly and whammo, down goes the spur?
Others probably got better info, its just your last post seemed to make me think of htat.
One nice thing I like about the exotek is no need for the brace as far as I am seeing.
Cain is offline
Old 09-10-2012 | 10:10 AM
  #29509
yea im kind of in a bind at the moment.. i will double check everything today.. it might be that bearing in the transmission case.. or the brace or the belt.. oh shoot might as well buy a new kit at this point..
Old 09-10-2012 | 10:13 AM
  #29510
fq06's Avatar
Acer racing titanium button head screws, $1 a piece (or close to it) and free shipping. Hasn't bent yet
fq06 is offline
Old 09-10-2012 | 10:20 AM
  #29511
Yes the bearing the shaft goes thru, I had to add a shim to mine as it started to bind, yours could be getting hot, and locking enough to strip the spur, check the belt can't get to tight with chassis movement, that could bind it maybe, my moneys on something binding and locking up someplace, up travel thru your axles etc, when you set your mesh, I'm sure you turn the spur all the way round?, shaft not bent?
RossNZ is offline
Old 09-10-2012 | 10:26 AM
  #29512
brand new top shaft... belt is not loose but not tight.. and i do turn the spur and check for play.. the only thing that hasnt been replaced is the bearings in the transmission case and motor plate.. bearings in the rear hubs are fresh.. bearings in the front are fresh too..
Old 09-10-2012 | 10:49 AM
  #29513
Venom is such a great company. Had me email a picture of my reciept and my battery with the negative lead cut. They sent me a new battery right away!
90da9 is offline
Old 09-10-2012 | 11:06 AM
  #29514
if the slipper is too tight that will cause the spur to strip?
Yes it will. If the slipper can't slip something has to give and the spur is the next weakest link.
Beachbuggyphil is offline
Old 09-10-2012 | 11:12 AM
  #29515
xDIRTYx's Avatar
Originally Posted by fq06
Dan & Cain, right on the money with the diff fluid. I run 5/5 with the C-Diff.
Dirty, do yourself a HUGE favor and have new gears for the diff when you pull it apart to shim it or you will more than likely be doing it a second time.
Order a couple 62 tooth spur gears from RcShox for spares along with the pins. You will more than likely end up running 6 pins once you drop the oil weight in the diff, but those wear so good to get some freshies.
Absolutely the first tuning change though is 5k front fluid.
On the temps, if you ask tekin they will tell you that you are geared correctly based on temps. I prefer 160, but I am not running the pro4. Add a fan with the 13 and your at 160 with more torque out of the motor and top end than the 12.
I come off at 150 after a heat but 180 during practice if I drive for more than 10 min.
Thanks for the imput guys, at least now i have a plan of attack. Im going to hit the lhs and pick up the kit with the new gears and shims & 5k diff oil. Does anyone have the part number for the kit i need? And ill order some new spur's and pins also.
When rebuilding the diff what is the correct amount of shim to use? I think i remember reading something about it but cant remember the number.
Thanks!
xDIRTYx is offline
Old 09-10-2012 | 11:13 AM
  #29516
Cain's Avatar
Tech Legend
.5mm I believe but you also don't use that shim that goes between the cup and the case. Again, from memory of what instructions AE sent.
Cain is offline
Old 09-10-2012 | 11:36 AM
  #29517
fq06's Avatar
Yeah, the new kits should come with the .5mm shims. One under each sun gear and remove the small shim on the outdrive on the outside of the diff.
AE # 9829
http://www.teamassociated.com/parts/details/9829/
You may want to get two and freshen up the front as well.
fq06 is offline
Old 09-10-2012 | 11:48 AM
  #29518
xDIRTYx's Avatar
will do, might as well do both of them since im going to change the oil anyway.
It is the same kit for both front and rear correct?
Im not sure I understand which small shim to remove, I guess ill figure it out when I see it
xDIRTYx is offline
Old 09-10-2012 | 12:52 PM
  #29519
ryanpatrickgore's Avatar
..5 shims only fit in my rear case.
The front case was shimmed properly with just the .2
I tried putting in .5's and way way to tight
FYI. Kinda odd.
ryanpatrickgore is offline
Old 09-10-2012 | 01:21 PM
  #29520
Jordan Anderson's Avatar
R/C Tech Elite Member
I thought it was a 0.3 shim to be used under the sun gear? (ie. http://www.amainhobbies.com/product_...r-5x15x03mm-10
) Or do you only use the 0.3 with the small outside shim as well?
So...
w/ small outside shim, use 0.3 under sun gear
w/o small oustside shim, use 0.5 under sun gear
Is that right?
Jordan Anderson is offline
