Losi 1/8 8ight E 4wd Thread >
Old 08-19-2012, 05:17 PM
  #8011
Quad Racer 34's Avatar
Trader Rating: 4 (83%+)
Originally Posted by tony montana
it shoudnt be but I have not checked it. My last spur only lasted roughly 5 laps.
It shouldn't have reached hot enough temps in that short amount of time then. The only thing I can think of is the mesh wasn't tight enough. (Not saying you dont know how to set it) I've raced about 5 times with my new E car with huge jumps, sections where I needed to be on the gas hard, and haven't had any problems. Same with a few other locals around here.
I set my mesh like how UN4RACING said he does his. As tight as possible without the gears binding up. And it's quiet out on the track as well.
Quad Racer 34 is offline
Old 08-19-2012, 05:24 PM
  #8012
tony montana's Avatar
Trader Rating: 76 (100%+)
I have noticed that on the motor mount that the spur looks to have rubbed the mount. The new spur I just put looks really close to the mount. The other ones looked close as well.
tony montana is offline
Old 08-19-2012, 05:27 PM
  #8013
Yes, the spur does sit very close to the mount. If you can move the diff in the diff mount, I would put some shims in there so the spur doesnt hit the mount.
Old 08-19-2012, 05:30 PM
  #8014
so I should just put some regular diff shims on the out drive rear bearing to shim it foward
Old 08-19-2012, 05:32 PM
  #8015
Integra's Avatar
.1-.2 MAX. You can "lock" the bearing's if your not careful.
Integra is offline
  #8016
Only if there is movemnt in there. You don't want to get it too tight because then you'll bind your bearings and cause them to fail.
Integra beat me to it! lol
Old 08-19-2012, 06:09 PM
  #8017
Trader Rating: 29 (100%+)
thanks for reply. Im just getting sick of stripping the 45 tooth plastic spur. I have a metal 46 tooth is the reason for me asking, and dont wanna buy the 45 tooth metal one lol. Im clueless to why I keep stripping the spur, I have the mesh just right. On other buggies that used plastic spurs I never stripped one. Just with the losi Im having issues.
In the last 3 years I've switched back and forth between plastic ans steel on the Buggy and Truggy. I've found it has alot to do with landings with brakes on or landing with full gas on that strips my plastic.
For what ever reason the Tekin RX8 esc seems to work best with plastic, stripped quite a few when using Castle MMM
15/45 is a sweet set up, I run 16/48 and DREMIL the chassis slightly for clearance, I've ran 17/50 on large tracks
Al
akesj1 is offline
Old 08-20-2012, 12:32 AM
  #8018
rcguy76559's Avatar
Trader Rating: 22 (100%+)
What chassis you guys running? I'm looking to replace mine its thin. I was thinking or getting the losi +2mm chassis. I'm currently running the stock flex chassis.
rcguy76559 is offline
Old 08-20-2012, 04:45 AM
  #8019
UN4RACING's Avatar
I have made all the "necessary" changes to my kit IMO as far as options. If I were to spend another dime on this kit the only thing would be a Tekno conversion Chassis.
UN4RACING is offline
Old 08-20-2012, 07:48 AM
  #8020
Integra's Avatar
I would stick with the Stock If it were me.
Integra is offline
Old 08-20-2012, 01:09 PM
  #8021
Guest
Default integra
integra have u heard anything about a new buggy yet??
And will the new proline bulldog fit the ele-buggy???
LOSIRACER77 is offline
Old 08-20-2012, 03:31 PM
  #8022
Guest
anyone???
Old 08-20-2012, 06:40 PM
  #8023
goehm's Avatar
Trader Rating: 45 (100%+)
I think it really depends on what's causing the heat to know if it can happen in 5 minutes. I had a very dirty motor bearing that was causing my spur to fail. I was chasing down gear mesh, movement of the center diff, bending of the motor/diff mounts, bearings in the trans, center bearings, diff gears, etc.
I didn't realize it until I started heat-gunning everything and saw that the pinion and center diff were at like 160 or so. Not sure how hot they were at the time of failure.
So if you're (OP) still having problems, pull out the temp gun and hit your pinion and diff gear and see where they're temping at. After running the TEN-SCTE for a while, I've learned that it's not a bad idea to temp the area with where the front and rear ring and pinions connect to the F/R driveshafts every so often. I've seen a few diff cases melt due to failed bearings and it's a good way to keep those in check. Failure of those is a PITA.
I've since replaced the motor bearing with a ceramic and have been since.
goehm is offline
Old 08-20-2012, 07:26 PM
  #8024
anyone???
http://www.rctech.net/forum/electric...ml#post7516533 there's a picture of an older bulldog body in post 4455 at the bottom of the page, I'd like to know as well about the 2012 bulldog body?
jnyrcr is offline
Old 08-22-2012, 03:13 PM
  #8025
so should I put the motor brace on or dont put it on?
