Losi 1/8 8ight E 4wd Thread
#8161
That was my thought is that the housing is not true. I am going to order the optional Heavy Duty differential housing that has the metal metal inserts LOSB3528
#8162
http://www.ebay.com/itm/Racing-Light...094#vi-content
#8163
[QUOTE=kipper1012;11340512]
Mine did the same thing. Finally figured out I had to remove one shim from behind the outdrive. It had 2 from the factory, which is what the instructions call for but it would bind up when I tightened the screws. It does leak some however.
Brian
Brian
#8164
[QUOTE=SUPERLOOPER;11343506]Thats strange I just checked, mine only has one shim not two. are you talking about the shim that goes under the pin that holds the outdrive cup in place ? thats weird my manual says X2 on that shim also but there is only one
#8166
The only thing I can think of is the case I ordered the Heavy Duty housing from Amain this morning so we will see. when you posted about the shims you had my hopes up that I would be back running it today :-( oh well this is a hurry up and wait hobby
#8167
[QUOTE=kipper1012;11344362]
[QUOTE=SUPERLOOPER;11344379]
Have a look at Adam Drake building a diff:
at 1:50 he suggests not to use the shims, only if your diff is leaking.
+ YouTube Video | |
#8168
LOL Thanks dtr I took them apart yet again and removed the shims and BAM spins like butter Thanks. BUT will it leak now is the question. either way I have a heavy duty one on the way so i guess if it dosn't leak I will have a spare
#8169
Does anyone else's car have huge belly slap off big jumps? is it normal?
#8170
Hi guys
Can anyone give me some advise on fitting a pinion gear?
My pinion keeps coming off.
In the manual it doesn't say that you have to use thread lock, but I have tried it and it still comes off.
Could it be that my gear mesh is not right?
Thanks in advance for your input.
#8171
sorry dbl post
#8172
Ive had mine come off. make sure you crank it down as tight as you can get it and let the lock tight cure before use.
Just got some lightweight out drives do they make any difference and how strong are they?
#8173
Hi guys
Make sure the setscrew is lined up with the flat spot on the motor shaft. I have never had to use thread lock on a pinion gear just make sure to really "crank down the screw"
#8175
The manual doesn't mention locktight on the grub screw, but it seemed obvious to me that it should have. Anyway, i'll try really cranking it down, I think that might be my problem along with not waiting for the thread lock to dry. Thanks guys...
