Like Tree5Likes
SC10 4x4 Thread
Old 07-25-2012 | 12:29 PM
  #27091
Wildcat1971's Avatar
Tech Prophet
wrong forum
Wildcat1971 is offline
Old 07-25-2012 | 12:30 PM
  #27092
Tech Prophet
Originally Posted by Cain
I was hoping that AE would make a hopup (or someone else) using replaceable inserts so you can adjust the toe-in, etc. that way.
for the front or rear?
Old 07-25-2012 | 12:38 PM
  #27093
Cain's Avatar
primarily rear.
Cain is offline
Old 07-25-2012 | 01:29 PM
  #27094
anyone having any voltage drops while running a castle mamba max pro and a spektrum 6040 servo and radio ?
twisted is offline
Old 07-25-2012 | 01:31 PM
  #27095
Tech Prophet
the mmp has a weak bec and the spectrum receiver is problematic. You will need a receiver cap/glitch buster. I assume you are talking servo voltage loss or "brown out"
Old 07-25-2012 | 01:34 PM
  #27096
drolmaeye's Avatar
They already make one for the front, no? The steering turnbuckles.
drolmaeye is offline
Old 07-25-2012 | 01:37 PM
  #27097
ryanpatrickgore's Avatar
Man nothing but heartache with the Savox / spektrum combo. Throw in a mmp and you got a recipe for disaster. Easiest solution. Ditch the spectrum or the Savox. I ditched the spektrum garbage and life Is better all around now. Rocking the mt4 and loving rc life
ryanpatrickgore is offline
Old 07-25-2012 | 01:39 PM
  #27098
Tech Prophet
lol, yeah. I was trying to be funny, I guess it was lost.....
Old 07-25-2012 | 01:43 PM
  #27099
drolmaeye's Avatar
I was trying to be funny too! I am too slow to pick up on subtle humor, my bad. Oddly enough, I am sure someone could cook up a reason why it is better to actually angle the hinge pins than just crank the turnbuckle . . . I've heard stranger theories on this forum.
Old 07-25-2012 | 01:50 PM
  #27100
BlueGlowBoy's Avatar
If you give it more than 10 degrees of toe in with the camber links, the joint between the turnbuckle and the ball-end becomes a weak point.
BlueGlowBoy is offline
Old 07-25-2012 | 06:14 PM
  #27101
SOuthernFRIED's Avatar
Some folks could get lost goin' in a circle.... Jus sayin
SOuthernFRIED is offline
Old 07-25-2012 | 06:26 PM
  #27102
Evil Genius jr.'s Avatar
How are you guys setting your servo saver? It's either way to loose our breaks.
Evil Genius jr. is offline
Old 07-25-2012 | 06:35 PM
  #27103
Mines as tight as I could get it. Still haven't broken one.
Old 07-25-2012 | 06:50 PM
  #27104
yea brown out is what i was referring to. i have a glitch buster that i can install when i put the system in. i was just reading that i can bump up the bec voltage on the esc ?
twisted is offline
Old 07-25-2012 | 06:52 PM
  #27105
Tech Prophet
Yeah. You can up the voltage
