Like Tree195Likes
Novarossi engines thread
Old 06-20-2012 | 03:59 PM
  #4336
I am new to 1\8 and have some qusetions,
I have a 21 PT, how hot do these normaly run?
I got two pipes, the 2015 and 2052 with 5 and 6 fin conical headers, what pipes works best on this engine and what combo normaly works best?
chovden is offline
Old 06-21-2012 | 04:27 AM
  #4337
rc10parin's Avatar
Good day I have a NOVAREX engine from the late 80’s for a RC500. Im looking for a replacement piston and sleeves or can someone help me for a suitable replacement in the current line of Novarossi engine
Any info will be greatly appreciated. Thanks.
NOVAREX 350 3port plus 1
here some spec.
Sleeves Piston
Inside Dia. --------- 16.63mm Outside Dia. ----- 16.63mm
Outside Dia. ------ 19.92mm Height ------------16.65mm
Head Outer Dia. --- 22.20mm
Height--------------- 13.06mm
Bottom to base of exhaust port ----10.05mm
rc10parin is offline
Old 06-21-2012 | 06:13 AM
  #4338
here some spec.
Sleeves Piston
Do not know, I am confused with your numbers.. The older Novarossi sleeves have a 19.2mm diameter and the later models 19.5mm. The RB WS7/S7C is such a square stroke P/S set (19.5mm) you can make to fit. And I think you do need a E-type rod (4.9mm)
But the price to fix this one is almost a new one. Get a Kangaroo or a Basic N21-5T or N21-7T and you will get a same performing engine.
Roelof is offline
Old 06-21-2012 | 07:32 AM
  #4339
rc10parin's Avatar
Very much appreciated. I don't plan to run it but it feels a lot better if the car and the engine run together. Thank's a lot
Old 06-30-2012 | 05:56 PM
  #4340
rbcts's Avatar
Hi all,
I am new to the nitro on road scene. I have been racing offroad (nitro and electric) for a while now and recently got into on road electric but am leaning more towards going nitro. I am looking for an reasonably priced Nova that will let me be competetive. What do you guys recommend? Thank you!
rbcts is offline
Old 06-30-2012 | 06:13 PM
  #4341
bfong13's Avatar
Originally Posted by rbcts
Hi all,
You going to be racing in the FORGASS? Assuming you're going to be racing 1/10 sedan? The Nova Flash PT is very good. Most places have it for around $369 USD or so. I'm currently running a Flash PT and a Murnan Keep-On, and they're both really good motors.
bfong13 is offline
Old 06-30-2012 | 10:48 PM
  #4342
rbcts's Avatar
Thanks for the help. If everything pans out my goal is to race in the FORGASS. I'm looking to race 1/10 sedan.
rbcts is offline
Old 07-01-2012 | 08:13 AM
  #4343
asw7576's Avatar
Default boca bearing
Ceramic Boca Bearing.
Is this bearing will do the job ? Somebody has ever use this bearing ?
I'm concern with the plastic retainers ( the ball cage ) might deform after 140Celcius.
asw7576 is offline
Old 07-08-2012 | 08:44 PM
  #4344
Default Buttonhead (35+21 and PT)
Can the buttonhead of the PT (Part # 28022/1) be used on a 35+21 (part # 28011)?
sammies is offline
Old 07-08-2012 | 09:32 PM
  #4345
Pooh2's Avatar
Yes.
Pooh2 is offline
Old 07-09-2012 | 12:03 AM
  #4346
Be aware that the fresh fuel in the crankshaft and bearings is giving a lot of cooling. No problems, the temperature will not even come close to that.
Roelof is offline
Old 07-09-2012 | 04:45 AM
  #4347
Hi,
Sydwc kangaroo done four litres and has a notchy bearing that make its soun like a deisel! The engines lost power and dies after long bursts of power. Is it worth replacing the bearing or should I just dump it?
xray man is offline
Old 07-17-2012 | 05:29 PM
  #4348
Hi,
Will the .21 FlashPT header silicon gasket (red), fit a the earlier novarossi .21 engines in place of the blue colored silicon gaskets?
Tried searching this forum, couldn't find info on this.
I read the the PT/PTS gaskets are a slightly different design, but was hoping they will still fit the likes of a 35plus.
Thankyou,
Brad
ace16 is offline
Old 07-18-2012 | 01:48 AM
  #4349
Questions?? Help! Looking for a backup 21 onroad motor
So I originally had my eyes set on the Nova 35 plus 21, but the JP Eagle 21 R-9s also caught my eye. For those experts out there, which would I be better off with? Any personal experiences between the two? This will go on my MRX4X. Your help is greatly appreciated in making a sound decision. Thanks for looking.
rip67vdub is offline
Old 07-19-2012 | 12:41 AM
  #4350
Anyone?
