Like Tree5Likes
SC10 4x4 Thread
Old 06-24-2012 | 07:07 PM
  #25576
yellow 2.2
blue 2.0
the other one is 1.8, I forget the collor
thanks !
twisted is offline
Old 06-24-2012 | 07:10 PM
  #25577
Originally Posted by ABN Hoosier
old top shaft
http://www.amainhobbies.com/product_...Rear-Top-Shaft
new top shaft
http://www.amainhobbies.com/product_...-Rear-Topshaft
I am not clear on what the difference is. I am kinda confused. I have the MTK clutch basket. Would the new Top shaft help? Is the new TS pinned? Should I junk everything and get the $8 exotech clutch? Weird they call it a front clutch. Is that because it's on the outside, kinda like on the top.
idk the difference between the shafts either.
the exotek clutch is not a clutch at all but a clutch eliminator. on the stock associated clutch the inner paid is used to control front wheel slippage and outer pad is used to control rear wheel slippage. the exotek replaces the inner pad and inner hub so its directly driven.no slip to the front wheels.
twisted is offline
Old 06-24-2012 | 09:01 PM
  #25578
NitroXray80809's Avatar
Hello i just picked up a new pre built kit. Builder wasnt all that smart and built it wrong/ruined some parts. But anyways im getting that all situated and for the price i paid its worth it. But im curious to what electronc set ups do you AE guys recommend in this car and also any hop ups you guys think are a must etc? Im a heavy racer so i want what makes it better not look better. Im already planning on sway bar kit but anything i need to increase durability etc? I plan to get a rx8 speedo but idk wha motor since its only a 540/550 sized car?? Thanks
NitroXray80809 is offline
Old 06-24-2012 | 09:22 PM
  #25579
SMR 510RR's Avatar
Tenshock SC411 4600kv or a Tekin Pro 4 are the hot tickets. I recommend the Tenshock as it is just as good as the Tekin but way cheaper!
SMR 510RR is offline
Old 06-24-2012 | 11:37 PM
  #25580
FACTORYBUTNOT's Avatar
I'm gonna try a Reedy 550 4.0 this week. I've been running a Tekin 4 pole 4000kv and it's kind of slow.
I'll let y'all know if the Reedy is the hot ticket...the 540 Reedy motors are great!
FACTORYBUTNOT is offline
Old 06-25-2012 | 12:59 AM
  #25581
ABN Hoosier's Avatar
Thanks for the explanation twisted. I just read this whole thread: http://www.rctech.net/forum/electric...-services.html
I think I will give this a go.... http://rcshox.com/shoxshop/catalog/p...products_id=58
ABN Hoosier is offline
Old 06-25-2012 | 06:52 AM
  #25582
Which is considered "better" the 550 or 40. I was looking at scx tekin 4.5 550 motor?
Old 06-25-2012 | 06:56 AM
  #25583
samuelsonmark71's Avatar
I ordered a 4 pole 540
samuelsonmark71 is offline
Old 06-25-2012 | 06:58 AM
  #25584
Wildcat1971's Avatar
Tech Prophet
A 550 will probably run cooler. I run a 540 and it enough power for me.
Wildcat1971 is offline
Old 06-25-2012 | 07:08 AM
  #25585
jamr1130 is offline
Old 06-25-2012 | 07:33 AM
  #25586
Deja Vu's Avatar
Moderator
My daughter's SC10 has been handling very well and the current set up is perfect for her driving style. I do have one continual issue though...
If I tighten the rear right tire like it should be, there is noticable drag when you give it a spin. Without tires, the driveline is silky smooth and very free. If I tighten it until it binds, then back off just a bit, the tire seldom stays on for an entire race. I've replaced the hex, the pin, the bearings and shimmed behind the pin. I've tried new tires and new lock nuts. I've even painted up the rear carrier, spun the tire and checked to see if it was rubbing. I've swapped tires around and still nothing.
Now that I type this, it just dawned on me that maybe the rear axle is slightly bent?
Anyway, any suggestions where to look or what to try next?
Thanks in advance...
Deja Vu is offline
Old 06-25-2012 | 07:47 AM
  #25587
Wild Cherry's Avatar
Daja
Take apart the rear hub and check if the aluminum crush tube (# 91033) is installed between the bearings.
Wild Cherry is offline
Old 06-25-2012 | 07:51 AM
  #25588
Deja Vu's Avatar
Moderator
Daja
Excellent suggestion...I hadn't thought of that.
Thank you!
Deja Vu is offline
Old 06-25-2012 | 07:59 AM
  #25589
Default Scotty Ernst Sc ShootDown @ TRCR
Sipppp
Aaaaah !
Nothing like Star Bucks at home after a really long weekend preparing for the biggest event in my life ....
Old 06-25-2012 | 08:00 AM
  #25590
BorackBasher's Avatar
Thank you!
that's the first thing i would've checked... is anyone running the reedy motors in the sc10? whats the gearing of choice and temps? currently have a lrp 4.5 geared at 62/11.. just curious how hot the reedy gets.. and i also tried the tekin 4 pole 4600 and that thing is a beast.. but a lot of torque for my liking but cant complain!
BorackBasher is offline
