SC10 4x4 Thread
wow so you guy are using the front springs for the rear of this car? That helps it out how? I just got my set up but it gonna be a couple of weeks before i can even try it on the street. racing season dont start till about may for my tracks. which are all out doors and big tracks. I read some said that used heavey spring in the rear cause of using the novik ballistic 550 4.5 t that what is setting in mine now any input would be good. i was gonna pick up a set of each for front and back of the truck but maybe i should order two front set?
Dirt
Think backward springs is something the guys with the ExoTech have to do ...
6oz's of extra weight to handle makes a truck that is lazy and they use to help .
Stock chassis performs better with the Yellows ...
Thanks cherry, I was thinking why would I move to a front spring with that high of a rate when my truck is light as possible. Making the move to blue fronts on the front and blue rears on the rear seemed to work really well for me. I might go back to yellow fronts on front and call it good for now. Seems like the only real way to tune my stuff is to do it myself to my preference. Getting tuning advise from someone else is hard because there are so kany variables.
Hence, the benefit of using heavier springs with your logic would be seen stock chassis as well.
As for whether there is a benefit or not, try it and see. Craig's explanation is probably the best on the "why". As for where to use it, I used the higher rates in both extreme low traction conditions as well as highest grip carpet. It works.
Hey guys need some help!! i have a used sc10 4x4 coming to me tomorrow, and i really need to know if i can use my regular 10th scale esc and motor with it. I am a 10th scale offroad racer that runs a 10th scale 2wd buggy, 4wd 1/10 4wd, and stadium truck. never ran 1/8 scale. i browsed thru this thread and really no concrete evidence if i can. i have a novak Kinetic. tekin RS, novak GTB, that i can use. is this possible?
If your looking for a cheap reliable setup go for a Brushless Hobbies ESc and Tenshock 4600kv that is what I run in my SC10 4x4 and it is wicked fast.
http://www.brushlesshobbies.com/LT4-...mer_p_113.html
I will say this, for those considering the exotek chassis versus sticking with the stock one, add the similar weights to the vehicle and see what you think. And also bear in mind that the exotek chassis will add weight to the vehicle at the lowest point possible.
And when you compare, make the appropriate changes to your shock settings.
http://teamnovak.com/products/index....products_id=40
sounds like it will work.
You can run 540 motors on it, however it appears you need to really watch your temps.
Bear in mind, the BLH ESC offers zero warranty. If you get one DOA you are out of luck. That has been the main complaints I have read about the ESC. At the price point and lack of warranty, you may find it better to just order the apparent HK clone that is like $38ish .
5Likes
