Like Tree5Likes
SC10 4x4 Thread
Old 06-13-2012 | 05:42 PM
  #24961
Wildcat1971's Avatar
Tech Prophet
Anyone racing with a Ten Shock? I saw some pretty good reviews on it from ultimate RC. I am just doing local club racing, as long as it don't not cog horribly bad or start on fire I should be good.
Wildcat1971 is offline
Old 06-13-2012 | 05:53 PM
  #24962
SCTDan's Avatar
I've been racing the SC411 4600kv for a few months. Very smooth and more power than you can use. Flawless so far and I have done my best to abuse the snot out of it.
SCTDan is offline
Old 06-13-2012 | 05:59 PM
  #24963
Tech Prophet
Which esc are you using? What C rating are you using for the pack? I read that motor has a decent amp draw. What about the 401? Its sensorless yeah, but does it cog bad? I have fried a few sensors in my 4x4 /sadface
Old 06-13-2012 | 07:46 PM
  #24964
jpure009's Avatar
Questions??
Originally Posted by fq06
Swaybars connect left and right arms together to reduce roll, if you release both tires they should both fall.
If you hold one tire, the other side will not fall. They will not fall independently of each other with sway bars connected... they will fall together without springs shocks or anything. They should move very freely, together.
The reason that they would not fall could be that there is binding in the inner hinge pin, outer pin or the nuts retaining the top of the shocks are too tight.
You may have tightened the nut too tight on the outer hinge pin.
Loosen up the nut on the shock, still tight and not dropping down? Loosen the nut on the outer pin through the hubs (both), still tight? Its gotta be the inner pin binding, time for new arms.
You can disconnect the swaybar to see if it is the left or right side that is binding.
Originally Posted by BlueGlowBoy
It could also be that you are using the wrong clips that hold the sway bar in position. There are 2 different clips with a total of 4 different sizes of holes that hold the sway bars. If you are using a set that is smaller than your bar, the bar will bind and the hubs/arms will not have free movement.
THX guys,
I have the Correct swaybar piece in there(#2 for Blue-2.0 bars)
i guess I could go bigger?
FQ,
i am saying without tires, no shocks....
When i raise the a-arm with my finger, should it fall back down??
My Rear A-arms look fine, I inspected & i changed hinge pins(NEW)
But, the Rear a-arms don't fall back down, everything seems to be fine,
so I guess it has to be the A-arm is bent & i can't see it?
I know not the most important thing, but i like it to be right!
THX
jpure009 is offline
Old 06-13-2012 | 08:19 PM
  #24965
Originally Posted by jpure009
THX guys,
FQ,
THX
your arms should fall by their own weight.
twisted is offline
Old 06-13-2012 | 08:24 PM
  #24966
This may have already been said but make sure your don't have the outer hing pin lock nut too tight. If you have it too tight it will keep the arm from moving freely.
jeff whiting is offline
Old 06-13-2012 | 08:31 PM
  #24967
darryl80's Avatar
Talking
i am waiting for my brand new sc10 4x4 factory team kit truck to come in the mail. also i bought the strc aluminum steering bell crank, rpm a arms all around, hard anodized aluminum belt tensioner pullies. i figured i mine as well buy those parts and install them on my truck right away.
darryl80 is offline
Old 06-13-2012 | 08:55 PM
  #24968
Jake S's Avatar
after looking through the manual and using the search function in this thread...
what shims under the sun gears? i cannot find an AE number that isnt a full rebuild.
tore my truck apart to start the diff bearing mod and noticed a shim wasnt completely flat, still run-able, but since i got the whole truck apart wanted to just put in new ones... tried the same shim from the outside on the out-drive, and with 2x on 1 side and 1x on the other the diff seemed really smooth and tight but no binding... would using the 10x5x.02 be an alternative to the 13x5x.02 shims?
Jake S is offline
Old 06-13-2012 | 09:16 PM
  #24969
fq06's Avatar
THX guys,
FQ,
THX
It should absolutely fall back down on it's own, if it doesn't, you are leaving a lot of performance on the table.
The a arm can look ok, but the plastic that the hinge pin passes through can get tweaked and create binding.
Before you get new arms though, loosen all points of tightness. Loosen the nuts on the outside hinge pins (at the hub), loosen the shock nuts on the tower, loosen the clip that holds the sway bar in place (even with it assembled correctly, if too tight can bind up. There is a small side and a big side to that part).
Hope I'm not forgetting anything.
Now does it drop freely? If so, the a arm is ok. If not, new a arms.
Now start tightening everything up checking for free movement as you tighten and you should get everything tight enough without any binding.
fq06 is offline
  #24970
darryl80's Avatar
Jake S,
if you call team associated they will send you 0.3 differential shims to you at no charge. they sent me 0.3 differential shims.
darryl80 is offline
Old 06-13-2012 | 09:33 PM
  #24971
the big rc's Avatar
Motor question.
I just picked up a never used tekin rx8 with a 550 5.5. My question is should i sell the 5.5 and get a 4 pole instead?
What are the advantages of either.
the big rc is offline
Old 06-13-2012 | 09:38 PM
  #24972
jpure009's Avatar
It should absolutely fall back down on it's own if it doesn't, you are leaving a lot of performance on the table.
Before you get new arms though, loosen all points or tightness. Loosen the nuts on the outside hinge pins (at the hub), loosen the shock nuts on the tower, loosen the clip that holds the sway bar in place (even with it assembled correctly, if too tight can bind up. There is a small side and a big side to that part).
THX again...
I already have new A-Arms.....
I think Its the plastic, where the Hinge pin goes is tweeked or bent.
Everything else seems to be fine.....
I will 2x check b4 changing A-arms tho, but I think that's it.
Just wanted to make sure.
THX
jpure009 is offline
Old 06-13-2012 | 09:59 PM
  #24973
kjohnsiii's Avatar
Originally Posted by the big rc
Motor question.
That motor is ok but.. you will really like the power, smoothness and torque of a 4pole. You can get by with that motor with a little bit of timing. With a 4pole you dont need any timing, it is a smooth beast of a motor, night and day power curve (smooth all the way up). The 4pole just feels much more efficient.
kjohnsiii is offline
Old 06-13-2012 | 10:01 PM
  #24974
FACTORYBUTNOT's Avatar
Daryl80-There is no need to instal those RPM arms on ur new truck...I've yet to see someone break a stock arm. The truck should handle better with the stock arms as they are stiffer. Be careful with that Strc alum steering rack. I tried a alum sc10 bulkhead a couple years back and it developed slop very quickly due to the softness of the alum used.
I'd suggest you build the truck and race it stock before you change things on it. Team Associated spent alot of time and effort developing the new parts and setup.
Jg
FACTORYBUTNOT is offline
Old 06-13-2012 | 10:04 PM
  #24975
mrjeremyaaron's Avatar
There was some discussion a few pages back about the std kit arms vs RPM version, general consensis was RPM much less flex therefore performance upgrade.
Has anyone done the FT kit arms vs RPM yet?
I sold my std kit weeks prior to buying the FT so didn't get a chance to directly compare, but i swear the plastics are upgraded to harder / stronger throughout the FT truck. Either that or i forgot what clean plastic looks like
mrjeremyaaron is offline
