Like Tree1Likes
Go Engine USA 2011 Thread
Old 05-22-2012 | 09:21 PM
  #2491
Flanno's Avatar
Originally Posted by Hypernator
I bought my new gxII 5RHO from my shop last week. They have been backorder a week or so, so I thought it was the mkII carb on it. It wasn´t! Is the newer carb mkII much better than the "older" carb mkI?
So, what is the needle settings on this then, please?
See post above # 2480
Flanno is offline
Old 05-23-2012 | 06:26 AM
  #2492
Thanks but I mean for the mk1 carb that I have. That settings is for the mkll carb l think.
Hypernator is offline
Old 05-23-2012 | 12:47 PM
  #2493
Flanno's Avatar
Oh miss understood, but sure I read it in here some where or maybe the other thread.
Flanno is offline
Old 05-23-2012 | 03:29 PM
  #2494
grizz1's Avatar
Hey Hypernator,
Just want to make sure we are on the same page with the carbs.
The motor you brought has the original "3" needle carb with chrome throttle slide - yes ? Not the "2" needle carb as distributed in the US ?
To the best of my knowledge no motors fitted with the original "3" needle carb, or any of those carbs by themselves ever made it into the US market (I am just assuming you are in the US).
The GXII has come out in three versions so far:
Standard GXII two needle carb
GXII with MkI three needle carb (for a limited time of around 4-6 months)
GXII with new MkII three needle carb (only released from factory a few weeks ago).
Standard "2" needle GXII carbs - HSN flush, LSN flush to start with. Lean from there depending on pipe and fuel etc.
MkI "3" needle GXII carbs - we found a good race tune with these using the 2072 pipe was - HSN 1.5 - 1.75 turns in from flush, LSN .25 - .5 turns out from flush
MkII "3" needle GXII carbs - these are looking to give a race tune at around - HSN .25 - .5 turns out from flush, LSN around .25 - .5 turns out from flush.
We are still running-in and experimenting with the new model. New owners have only had them here for around a week, so early days as far as full on race tunes go.
grizz1 is offline
Old 05-23-2012 | 08:16 PM
  #2495
grizz1's Avatar
Oops double post
grizz1 is offline
Old 05-23-2012 | 09:32 PM
  #2496
Thanks alot grizz! That info realy help us racers here in sweden. Great!
Old 05-24-2012 | 02:47 AM
  #2497
grizz1's Avatar
MkII 3 needle showing white insulator and new anodised throttle slide.
grizz1 is offline
Old 05-24-2012 | 01:06 PM
  #2498
Flanno's Avatar
Flanno is offline
Old 06-02-2012 | 12:57 PM
  #2499
Default 3-needle tuning
I've had so much great performance with my current Go motors that I went ahead and got the new one. Now questions on the tuning strategy for the 3needle carb.
On my GX5R I like to get the top end close, then tune for good low lean idle, then tune the top end just above lean bog and test on the track.
With the GXII5RHO MkII 3needle, what is the best tuning strategy for truggy once it is run in? Does it tune more like the short LSN or still the same long LSN?
AZTman is offline
Old 06-02-2012 | 05:09 PM
  #2500
What's the recommended glow plug for a GXII-5R w/2072 pipe? Don't remember if I saw it in this thread or the other one. For some reason my iPhone won't let me search for some reason.
Mototech is offline
Old 06-02-2012 | 10:36 PM
  #2501
well im useing the O donnel T97 at the moment and that does well for the engine and holds a real smooth idle.. at temp especially...
MasterComander is offline
Old 06-03-2012 | 03:03 AM
  #2502
grizz1's Avatar
Hi AZTman - Tuning strategy is pretty much the same as for the long LSN.
The 3 needles still have the long LSN set up, but the HSN is far more adjustable than the 2 needle. With the 2 needle you were adjusting no more than a couple of hours in from flush on the top end - with the 3 needle you can adjust in 1/8 or 1/4 turns. Much more user friendly.
Mid range fuel tube is air flowed and set at the factory for peak performance, and it's recommended not to adjust this. If you feel you absolutly can't resist having a tinker, reference the factory setting first - but honestly it's best left alone (like all other mid range needles / fuel tubes).
Ball park figures running the 2072 pipe, 97T plug and Byrons ProDriver 30% fuel - HSN 1.75 turns in from flush, and LSN 1/4 turn out from flush.
This is at sea level and around 17 - 20 deg C.
O'Donnell 97T is pretty much all we run in these motors. They perform great and last for ages
grizz1 is offline
Old 06-03-2012 | 04:29 PM
  #2503
sickpuppy1's Avatar
Hey guys. I have a silver head 5 port engine that has barely gone thru break in. Seems most of the go rods are the same, but places like amain show a 15.5 and a14 mm wrist pin. So seems to me theres some confusion somewhere. any ideas on what to get.
And by the way, these older version carbs were a pain enough, mine has an OS20C carb on it
sickpuppy1 is offline
Old 06-03-2012 | 06:14 PM
  #2504
sickpuppy1's Avatar
second question would be the pipe. Got an 801 GO pipe when I bought it. Whats the difference between it and the 2072 that seems to be preferred?
Old 06-03-2012 | 07:03 PM
  #2505
motomatt's Avatar
Originally Posted by sickpuppy1
Hey guys. I have a silver head 7 port engine that has barely gone thru break in. Seems most of the go rods are the same, but places like amain show a 15.5 and a14 mm wrist pin. So seems to me theres some confusion somewhere. any ideas on what to get
Those dimensions are quoting wrist pin length.
21= 4x14mm
25= 4x14.75mm
28= 4x15.55mm
21GX engines = P-0414-3
21GXII engine = PS-0414
25Pro = P-0415
28Pro = P-0416
motomatt is offline
