RC10B4.1 FT/WC
Old 05-05-2012 | 10:27 PM
  #14341
DanielC.'s Avatar
Originally Posted by Crash74
I am off by 2-3mm, will check to see if they are screwed in all the way. I am running the Traxxas spring retainer not the Losi, could be my problem. I know other guys run the Traxxas with no issue. I run 2 limiters in the rear.
Make sure you are running the correct losi white springs. They make them for both the 22 and 22T. Had a local racer with a similar issue due buying a 22T yellow for the rear by mistake.
DanielC. is offline
Old 05-05-2012 | 10:50 PM
  #14342
If you're using the traxxas cup, make sure you SQUEEZE the cup onto the shock end. The losi one may fit better but the losi one is a bit taller so it almost balances out.
Kuya_Kimo is offline
Old 05-05-2012 | 11:02 PM
  #14343
LOSI123's Avatar
Does anyone know which of these rims are acetone safe?
-Original Associated b4 rims
-Proline B4 rims
-Jconcepts rulux/mono
LOSI123 is offline
Old 05-06-2012 | 01:19 AM
  #14344
pink_sleeve's Avatar
-Proline B4 rims
I've never saw acetone damage wheels before. Tires and foams yes. I've used acetone on all 3 of the wheels you have listed and many others and never had a problem.
pink_sleeve is offline
Old 05-06-2012 | 02:14 AM
  #14345
B00t13g's Avatar
Does anyone have gearing reccomendations for an 8.5 with a 78 tooth spur? I ran 78/22 with my 22 which puts me at a 8.6 fdr so should I shoot for the sane thing with the b4.1? That would put me at 78/23
B00t13g is offline
Old 05-06-2012 | 02:46 AM
  #14346
huzzler's Avatar
Originally Posted by JEFFs SC10
funny all the guys i know who have been running b4's, went to 22's and never looked back.
B4's are still winning big races. Stock nationals were b4's first and second place. Oh and t4's.
huzzler is offline
Old 05-06-2012 | 05:56 AM
  #14347
Crash74's Avatar
Thanks, thats what it was. They gave me 22T white springs, the yellow's I picked up are shorter. Will have to make a return trip and get the right ones. Thanks guys.
Crash74 is offline
Old 05-06-2012 | 06:20 AM
  #14348
Hey guys, just had my first race with the car( 1st ). It was very good and stable.
I managed to brake one of the wing mounts, but because I know from the time I used to race T4 that those brake easily I had some spares.
Has anyone modded the gearbox so that wing mount on the slipper side could be replaced without unscrewing the motor plate or has anyone customized sc10 rear body mounts to work as a wing mount(they look a lot stronger than the original part and the plastic seems better too)?
Marten is offline
Old 05-06-2012 | 08:24 AM
  #14349
Originally Posted by IRM616
is it better to run shorty or long lipos? and why??? thanks
Shorty lipos are great. However full size packs are good as well. I believe a lot of it will come down to driver preference.
dirt_oval is offline
  #14350
hey guys, i just bought a few parts for my b4.1 and one of the items were the factory team sway bar. what does the sway bar do? thanks
blitz98 is offline
Old 05-06-2012 | 08:29 AM
  #14351
The sway bar, or anti-sway bar, does exactly what the name implies. It prevents the roll tendency the car will have on carpet, concrete or other higher bite surfaces.
Old 05-06-2012 | 09:23 AM
  #14352
t0p_sh0tta's Avatar
What do you guys use to check toe? So far, I've done pretty well to just eyeball it.
t0p_sh0tta is offline
Old 05-06-2012 | 09:30 AM
  #14353
BigJohnRacing's Avatar
Default Top
I have always just eyed toe-in as well, and done fine. Recently I built a 22T and measured off all the specs from TLR and the truck does not preform as well as any of my eye-in builds.
BigJohnRacing is offline
Old 05-06-2012 | 04:29 PM
  #14354
I just got a tekin rs pro with my stock rtr3300kv motor and was wondering what would be a good starting point for the esc settings and gearing. I will be running mod class on a small to med indoor traction with med traction. Any responses will be greatly appreciated! Also can I even run boost or timing with sensor less motor
chancejeff is offline
Old 05-06-2012 | 05:11 PM
  #14355
JohnB's Avatar
Originally Posted by chancejeff
I just got a tekin rs with a tekin17.5 i was wonder what would be a good starting point for the esc settings and gearing. I will be running stalk class on a small to med indoor traction with med traction. Any responses will be greatly appreciated!
Are you running boosted or blinky mode?
I am geared at a 72/31 in blinky mode on our local track. 75'x65' indoor. A couple weeks ago at the April Fool's Classic where boost was allowed I ran preset boost #3 at a 72/32. Watch your temp and keep gearing up until you hit about 140-150* then gear down for feel if want to.
JohnB is offline
