Like Tree5Likes
SC10 4x4 Thread
Old 05-04-2012 | 04:22 AM
  #22636
ilanstylz's Avatar
Originally Posted by jpure009
THX,
I ordered it(Exotek), 107$ total w/ shipping.....
Like i said, i will drill the holes in the chassis I have,
then I'l have both....
I bought 2Gens Ace Lipos & 1 Orion 5500mah 90C
Saddle Packs TUBES w/4mm Bullets.....
So, I went 2 cheaper batteries, for now.
Question:
The Black&Red wire from my ESC,
I can put Bullets on each 1& plug str8 into the
Saddle packs correct?? Instead of Deans connections.
That way no wires coming from battery...
Will it work like with the Stick packs??
I know with the Gens Ace stick packs that is how
alot of PPL do it.
THX
Yes you can as shown in a pic here:
ilanstylz is offline
Old 05-04-2012 | 04:41 AM
  #22637
ShortCourseOnly's Avatar
All of Ae's top improvements all in one package......
heck of deal !
#91174 FT upgrade kit
www.rc10.com
I baught this kit for mine. I needed the chassis brace after casing a really big jump and throwing the belt. I replaced the belt with a new one and added the STRC tension pullies and the VTS slipper at the same time. Well worth the money. I don't have proper saddle packs yet so I will run the stick pack until I do get something good. Was considering the Reedy 60c packs. Won't be able to get anything too soon anyway.
My truck is the original kit with FT hex kit, sway bars. yellow springs, FT chassis brace, VTS slipper, STRC tensioners. I am lacking the FT Shocks and TiN hinge pins, light weight outdrives and aluminum hardware of the FT kit to get up to snuff with the latest. I have not upgraded to the Exotek chassis but it would be nice to. I will be running on large 8th scale tracks in Brazil so could use a little more low slunge weight.
ShortCourseOnly is offline
Old 05-04-2012 | 06:02 AM
  #22638
MantisWorx's Avatar
Originally Posted by ilanstylz
Yes go with the blue springs in the rear, and don't listen to those that say the exotek isn't worth it because most likely they haven't even tried it. It is def. worth the money and I was even skeptical in the beginning but couldn't be happier with mine........
+1! No one that has one or tried one has complained
MantisWorx is offline
Old 05-04-2012 | 06:14 AM
  #22639
vito's Avatar
Vito , I run the 5.5 550 Novak all the time & use a 16T & boost
you ? suggest 15T and leave timing alone or adjust 0 to +1 degree...
Hows the new pad ?
Saw Bridgewater's 4x4 today , gona have to get the new Team now.....
its small got my inter net hook up took 3 days on the phone. got to sell some toys dont all fit here
vito is offline
Old 05-04-2012 | 06:35 AM
  #22640
vito's Avatar
re set my epa at 150 from a 100 will that help?
vito is offline
Old 05-04-2012 | 06:42 AM
  #22641
Anyone have a source of the version 2 Exotech chassis? Local shop has v1, but I want to utilize the FT saddle pack cradle. Stormer shows some in stock, but isn't clear on which version would actually arrive.
negatv1 is offline
Old 05-04-2012 | 06:56 AM
  #22642
Cain's Avatar
Originally Posted by Mizchief
It's expensive but it's not a rip-off. I doubt the make more than $20 profit on each given the quality of the metal and the time it takes to mill it.
Funny thing when I ordered my chassis from trick parts I actually got in the invoice of what Exotek charges trick parts for the chassis. was interesting to see how markup goes. They and the places selling it aren't making a big killing thats for sure.
+1 . Awesome upgrade.
Originally Posted by Unlovedracer
Can you guys list the top improvements you can buy to get the most out of it if money is not an option? if money is an option? If you do can you provied links to the listed item to?
I'll bite, Assuming you start with an FT SC10 4x4:
- Exotek Chassis
- Basically all the RC Shox stuff except maybe the ackerman bar (since you do get the AE updated one)
- Front spring kit
Those would be on my list to purchase right away. I would also consider the alloy servo saver assembly that I think STRC has out.
Cain is offline
Old 05-04-2012 | 07:33 AM
  #22643
slow_jun's Avatar
Hi Guys,
considering to get my son a FT, but just want to get some feedback as on how it is when its maintenance time, i know its a great car but from the looks of it looks like i would break an arm and a leg just to pull out the tranny to change the oil... i may be wrong but would appreciate feedback from you guys.
Thanks,
slow_jun is offline
Old 05-04-2012 | 07:38 AM
  #22644
t0p_sh0tta's Avatar
It does take some time to get to the diffs, but this thing is tough!
t0p_sh0tta is offline
Old 05-04-2012 | 07:39 AM
  #22645
Cain's Avatar
its definitely not as easy as other vehicles thats for sure. But, once you get used to it, its not that bad.
Cain is offline
  #22646
If you start from the RTR or original kit I have the following list that I am recommending to a friend:
Upgrades for the SC10 4x4 RTR
- FT Upgrade Kit ASC1174
- FT Aluminum Wheel Hexes ASC91171
- FT Rear Sway Bars ASC91124
- FT Front Sway Bars ASC91123
- AE 13mm Front Springs Yellow ASC91162 (use blue front in rear)
Clearly the Exotek chassis would be good but he is not racing and we are in Brazil so this is a little more of a stretch.
Old 05-04-2012 | 07:41 AM
  #22647
murky123's Avatar
ik can be quite a pita to try it fast in the beginning. but once you done it a few times it is not a hassle anymore.
I recall that someone on this forum explaned it how he did it in 5 minutes. dont know who , sorry
murky123 is offline
Old 05-04-2012 | 08:42 AM
  #22648
treky11's Avatar
I was wondering the same thing. I sent emails to both exotek and to stormer yesterday but I haven't gotten a response from either yet.
Anyone hear have a v2 chassis and a factory team kit built?
treky11 is offline
Old 05-04-2012 | 09:11 AM
  #22649
spunkysandoval's Avatar
Originally Posted by kjohnsiii
Nice shot! What kind of camera is that shot with?
D700 i think. I'm not a camera guy, but when I was checking it out I saw that number on the side.
spunkysandoval is offline
Old 05-04-2012 | 09:19 AM
  #22650
Default Exotek from Stormer
Originally Posted by fq06
Oh yeah, I guess that is figuring in the rubber bumper on the shaft. I run a 1mm & 2mm clip under the rubber bumper.
I guess that rubber bumper thing must be 5mm?
I just spoke with Stormer Hobbies and they have them in stock. Bought one and they said they would ship it priority for their asked S&H fee. Looking forward to seeing the improvent in handling after running my FT for a while without, be an interesting comparison and will post up once I get a little time with it.
FTsc104x4 is offline
