Team Associated TC6 Thread >
Like Tree20Likes
Old 04-24-2012 | 06:53 AM
  #6646
carl jr's Avatar
Hi I just got a 6.1 and wanted to know if anyone has any setups for rubber tire carpet.
carl jr is offline
Old 04-24-2012 | 09:16 AM
  #6647
Chaz955i's Avatar
rc10.com has a bunch of them.
Chaz955i is offline
Old 04-24-2012 | 09:20 AM
  #6648
Is there a way to keep the front belt from touching the rear part of the top deck?
MySlowZ is offline
Old 04-24-2012 | 06:33 PM
  #6649
LasagnaCat's Avatar
Which diff cam holder are you using, and at what setting?
LasagnaCat is offline
Old 04-24-2012 | 06:37 PM
  #6650
bvoltz's Avatar
Originally Posted by LasagnaCat
What were you using? We went through a few last year (at Leisure) that ranged from bad to worse until we tried and stuck with the LG2.
Sorry I did not see this... LG2, first time with it.... I was thinking this may be some of the problem, but after your post, that is not the issue.
So how does one tell if the belt is slipping? Could this be the cause of my handling issues?
bvoltz is offline
Old 04-24-2012 | 07:32 PM
  #6651
I'm using the stock settings. I sanded the top deck a little, hope this helps. When I replaced the front belt, the teeth was worned out in an angle. \|
MySlowZ is offline
Old 04-24-2012 | 11:57 PM
  #6652
Hi guys would installing a 4 deg caster block rather than my existing 6 deg block help me turn faster in the low speed technical section? I have had my steering knuckles flipped and anti dive making effective caster at 5 degrees. No anti roll bars at a med size asphalt track.
I was also thinking about adding ackerman. Would that help?
zzztech is offline
Old 04-25-2012 | 01:22 AM
  #6653
From my previous testing i would rather go to the ackerman option.
jorgesimes is offline
Old 04-25-2012 | 02:52 AM
  #6654
Can you please elaborate a bit on this option?
thx
zzztech is offline
Old 04-25-2012 | 05:25 AM
  #6655
Brother, do you mind to take a pic and point me out where is Ackerman for tc6? Thanks
icefish is offline
Old 04-25-2012 | 01:12 PM
  #6656
IndyHobbies.com's Avatar
I've been keeping the belt on mine a little tighter than I did on my TC5 for that reason.
IndyHobbies.com is offline
Old 04-25-2012 | 02:05 PM
  #6657
I dont have the problem that the belt is touching the rear. Isnt your deck tweaked?
dennisV is offline
Old 04-25-2012 | 03:55 PM
  #6658
thx
I could elaborate here for 10 pages, but in the end it's all on practice. So there's nothing like you try it.
it's all on page 26 of the manual of the TC6.1 and on page 23 of the TC6, if you need more help say it.
Old 04-25-2012 | 04:37 PM
  #6659
jhautz's Avatar
Hey. I just got a TC6.1 kit and put it together. I'm trying to gear it for blinky 17.5 and I'm being told that I should start around 3.6-4.0 FDR at the track I'm going to run. So i got the optional 72T spur gear but with that gear there isn't holes in it like the stock 87T gear so I cant get to the back motor mount screw to tighten it down? I thought about drilling a hole in it to allow myself to get to the front motor screw, but Im afraid it will need to be to close to the actual teeth of the spur and it will weaken it. I see there is another screw hole that lines up with the bottom screw on the motor. Should I be just using the front and bottom screw? Or is there another solution I'm not seeing to be able to tighten the back motor screw?
Thanks in advance for the help.
jhautz is offline
Old 04-25-2012 | 04:55 PM
  #6660
Losiho's Avatar
Yes, use the 3rd mounting hole (bottom hole) when using small size spur gears.
Losiho is offline
