SC10 4x4 Thread
Is the strc steering rack a must have? How about their hinge pin supports?
I want to make my truck as bulletproof as possible before I start running the crap out of it.
I already added front and rear swaybars, ft aluminum wheel hexes, ft lower shock mounts.
What else should I be looking for? I believe the rtr comes with the V2 slipper already but is a center diff a better option for racing?
Also should I ditch the stock rtr shock oil and redo them? And if so what is a good setup? Losi 35 front and 30 rear sound close? Rebound? Half, full or none at all?
I replace whatever breaks with aluminum to an extent... no aluminum a-arms or anything stupid.
I replaced the rear arm mount cuz it broke.
There's not much on the chassis that's fragile and needs replacing though.
I think the C-Diff would be much better than the slipper and I have heard that feed back from others but I won't have mine till next week to say for sure.
Losi or AE fluid 30f/25r in my opinion. While you are at it, pull the screws out of the shafts, clean and blue locktight then reassemble.
I replace the steering rack with aluminum on all my cars to get it as slop fr add possible... as a general rule.
I will go do the oil change now. I have no clue what the rtr shock oils are but it feels a tad stiff.
Also are most of you running rebound or not? Half rebound full rebound or no rebound?
Can someone post pictures of the shorty's in rear setup or give a list of the parts needed to accomplish it? I put the garodisc on my stock slipper this weekend and I noticed alot more on-power acceleration. Like the power was always there anytime I needed it. But, what I noticed was that I was having a hard time with the big jumps. Normally, before the garodiscs what I use to do is wait until I was on the jump then max it, and it used to jump flat in the air most of the time and land smooth. Now, if I try that approach to the jump it would jump nose high until the battery lose some power. Then, it would jump normal again. I also went from 12 to a 14 pinion. I loving those garodiscs, but I have to do something with those big jumps. It was fine until I went to the 14 pinion and garodiscs, but I don't want to change those because I like the always available power from the garodiscs and the extra speed on the backstretch from the 14 pinion.
I want to try the Shorty's. Any pictures of it?
OMG what a difference white grease makes. lol my first run, i made a mistake and used black grease and it sucked. i cleaned up my mess(center diff) and it runs awesome. i think the 4600 is too much power, running my 4000 next time i hit the track.
question...
how do i setup my my rx8 with mathis inline saddle?
and if i have the exotek chassis do i really need brace?
thanks
question...
thanks
5Likes
