B44.1 Thread
#1831
I tried both, I like the Kyosho springs better IMO, I'm running yellow fronts and white rears. I was able to take the turns faster and jumps were a lot smoother.
#1832
I started on the Kyosho yellow/ white setup but felt I needed a slightly softer front spring so I tried a Losi Blue on front and liked it a little better. I dont think Kyosho springs are "better" than losi, I think its more of a tuning thing.
#1833
This is true... 2 of my buddies run the 1257/1258 and they have slight rubbing on the servo case and had to dremel a touch. On mine, no rubbing at all.
jamr1130, my bad. I said white fronts / red rears last week, but I just realized that they are yellow fronts / red rears. I got it mixed up with the white front / gold rears on my 2WD.
#1838
what do you think i should look at not sure where to start any help would be great
#1839
i like running a stiffer front and the rear softer i have do to much testing with the springs I'm looking for a little stiffer in the front than stock AE and not to much stiffer in the back but also stiffer than stock
#1842
Ok guys so I just order a b44.1 and I was looking at Mamba Max Pro 6900kV. What does that mean as far as turns is it like an 8.5t? I am new to electric I dont really know what any of that means and by the way is that a good motor Thanks for the help.
#1843
If you have alot of rc experience a 7.5 would be better and if thats not enough you can boost it a bit, but if your just starting to drive i would say a 10.5....I'm running lrp esc and lrp 6.5 boosted 1 level and its amazingly fast...
1Likes
