B44.1 Thread
#1683
Yeah I've read it all twice. I decided on a 7.5 turn motor and 18t pinion gear to start. I am still not sure what batteries to buy however, I will mostly be bashing this with friends in my area and was considering a 6000Mah 35C battery. My question is about what can I expect from it runtime wise? Also do you think it will provide plenty of punch? I am just getting back into RC I haven't owned one since my Avante in '89. I was 10 at the time and it seemed like a bullet, of course it probably didn't even do 20mph. I am so buying one of the re-released ones but first I wanted something that could keep up with my friends rides.
#1684
#1685
I would start with a 17p. Build the diffs with all 6 shims on the gear side and over grease the diff gear with 5 spots of Ae diff grease. It will break in and free up pretty quick so if it feels tight don't worry. The diff gears will hold up longer with that kind of nuclear power your running. Start with the kit set up and add the 87gram ballast between the packs. Should be all about tire selection from there. If the track is loose then run the B option hub and the inner top deck ball stud hole. Good luck. Keep us updated on the build....
#1686
WARP SPEED IN THE STRAIGHTS>>>>>>
#1687
Wow is that all I'll be able to get out of a set of batteries? I figured I'd at least be able to bash it for 30 minutes or so.
#1689
If you're power plant is smooth on the bottom end run a 3.5. My new kits 8 Weeks old and I ran a 5.5 and a 6.5. Still haven't chucked a gear and the diffs are still pretty smooth. Slipper setting and good trigger control is all it takes. You don't need a lot in the infield but all the power you can have in reserve comes in great for the straights. Power up.
#1693
#1695
1Likes
