Like Tree1Likes
B44.1 Thread
Old 12-27-2010 | 10:11 PM
  #181
Default lipo weight
do u guys run the lipo weight between the packs,its 90 grams
is that to much weight?????
do u guys run the undertray???
ghost rider is offline
Old 12-27-2010 | 11:33 PM
  #182
bjholz's Avatar
I am going to get the weight as soon as my lhs order comes in. And absolutely run the under tray. A $80 a pop for the chassis, i cant afford not to
bjholz is offline
Old 12-28-2010 | 12:22 PM
  #183
Weazsel's Avatar
From what I've heard, BOTH the ballast weight and the tray are a must!
Once the carbon fiber gets cracked or scraped it will eventually fall apart!
Weazsel is offline
Old 12-28-2010 | 07:13 PM
  #184
better is chasis tape from blackbeard rc the best you can get
vanderham21 is offline
Old 12-30-2010 | 09:23 PM
  #185
bjholz's Avatar
Have stock manual settings, but getting serious pushing. How to fix?
bjholz is offline
Old 12-30-2010 | 09:44 PM
  #186
i1justin's Avatar
check servo saver tightness, black sway bar instead of silver, 30 wt up front instead of 35, tighter front diff over looser rear diff, inside on arm on front and rear...
Some of the quick starters i have used in the past.
i1justin is offline
Old 12-30-2010 | 11:35 PM
  #187
Jason Turner's Avatar
My B4.1 is having serious issues pushing but my B44.1 steers soooo much.
What battery are you using? Using the ballast weight?
Jason Turner is offline
Old 12-31-2010 | 05:24 AM
  #188
kyle3333's Avatar
I run the ballast weight and it's awesome. The chassis protector works great. But in addition I sanded and glued the edges for extra insurance.
If you car is pushing, try different tires. I actually had the opposite problem. I was running pink BK Bars all over and had way too much steering. So I switched to pink Taper pins and that give the car a comfortable amount of under-steer. But, a little too much, so I swapped out the black sway bar for the silver.
Hope this helps.
kyle3333 is offline
Old 12-31-2010 | 05:25 AM
  #189
kyle3333's Avatar
Questions??
When is AE going to post the manual for the B44.1?
kyle3333 is offline
Old 12-31-2010 | 06:17 AM
  #190
Jmuck69's Avatar
Its up! i downloaded it 2 days ago.
http://www.teamassociated.com/pdf/ca...1FT_manual.pdf
Jmuck69 is offline
Old 12-31-2010 | 08:17 AM
  #191
cnelson3's Avatar
i run that and then about an ounce and a half. really helps to plant the rear end and stabilize the monster.
cnelson3 is offline
Old 12-31-2010 | 08:23 AM
  #192
RCHR's Avatar
The optional B44.1 ballast weight is 3 oz, which is close to the correct weight for a battery in the 4200mah weight range, running a larger battery in the 5100mah range only needs about 1.5oz of weight.
RCHR is offline
Old 01-01-2011 | 04:15 AM
  #193
Default body
what do you guys think of the punisher b44.1 body. it seems very unstable to me.
so i put my j cons body on and car was dailed,i think the new b44.1 body is no good, in my opinion what do you guys think,has any one tried the bulldog body??
Old 01-02-2011 | 09:31 PM
  #194
Anyone here have any gearing and speedo setting recommendations for a B44 with a kinetic/ballistic 13.5 combo for a 90 foot straight? Thanks!
Old 01-03-2011 | 06:52 AM
  #195
81/18 or 19 i run a 8.5 on about a 130 ft straight so you should be good with a 18 or 19
