Like Tree1Likes
B44.1 Thread
Old 04-05-2012 | 09:08 PM
  #1846
smittyusmc's Avatar
Originally Posted by fastchvy
Its around 5.5-5.0 turn
Oh got ya I have no Idea thanks for your help.
smittyusmc is offline
  #1847
fastchvy's Avatar
Originally Posted by smittyusmc
Im not new to rc I have been running nitro for about 5 years now. So what turn is 6900 I was thinkin it was around 8.5 or 7.5.
5200kv is a 6.5t from lrp
fastchvy is offline
Old 04-05-2012 | 09:39 PM
  #1848
smittyusmc's Avatar
Is lrp better than Mamba Max?
Old 04-05-2012 | 09:52 PM
  #1849
fastchvy's Avatar
Lrp is roar legal and i think mamba ( castle creations) isnt...you can check out orion and reedy also...lrp run hot, reedy blows up without warning and i dont know about orion...my lrp runs around 170* and never gives an inch...they say it can run around 200* but i dont see why...im going to try the new lrp x20 6.5t next...they all are good motors just whatever you like...just go to all there websites and read up..castle has good stuff but depends on what racing you do, club racing is ok but big races i dont think so
fastchvy is offline
Old 04-05-2012 | 10:00 PM
  #1850
smittyusmc's Avatar
That makes sence I was just looking at the tekin rs pro 8.5t and 7.5t and they look good too. So is 170* a good temp for these things and what would you do to make them run cooler if they were getting to hot.
Old 04-05-2012 | 10:03 PM
  #1851
fastchvy's Avatar
Tekin is good too, and they do run cooler then lrp...thats a good set up
fastchvy is offline
Old 04-05-2012 | 10:06 PM
  #1852
smittyusmc's Avatar
Ok good then I think that will be the setup I go with. Thanks for all of your help.
Old 04-05-2012 | 10:25 PM
  #1853
Originally Posted by Mini8 Menace
i like running a stiffer front and the rear softer i have do to much testing with the springs I'm looking for a little stiffer in the front than stock AE and not to much stiffer in the back but also stiffer than stock
what do you think i should look at not sure where to start any help would be great
sorry for the late response
I know the standard silver fronts are 4.85lbs according to the manual
losi green fronts are 3.5lbs and the blues are 3.8lbs So I am going to try a slightly heavier shock fluid first if no dice I will install blues, The rear of the car feells good but I will experiment until I find a good setup to my overall liking
Also I ran an LRP/Sonic Setup until last night(speedo decided it wanted to blow up)...about 2 months old. I think I am gonna go tekin/sonic and see how that works
NitroLuver is offline
Old 04-06-2012 | 05:50 AM
  #1854
Asharus's Avatar
Why would you want to shave it that would weeken the structure of the bell crank i went with the hitech 7940 and it fits perfect plus it's got better tq
I don't know, maybe because they already had the servo and wanted to make it work? If my 1258 didnt fit I probably wouldn't have shaved anything down either and just put a servo in that fit.
Originally Posted by NitroLuver
I have losi greens up front and yellows out back but it feels like the front is a little soft. running losi 35 wt front,30wt Rear. I think Imma try 37.5 up front and work from there.
I ran black fronts yellow or white rears before I ran kyosho yellow/red. Car handled/jumped/landed much better with the Kyoshos
Asharus is offline
Old 04-07-2012 | 03:06 AM
  #1855
I am going to experiment until I find a good combo, but the buggy was terrible tonight it was almost like driving a 2wd w/6.5T motor, had to baby it around a lot of corners
Old 04-08-2012 | 10:41 AM
  #1856
Anyone have a good gearing for a 13.5 viper motor? Running the stock spur.
dbracn is offline
Old 04-08-2012 | 04:54 PM
  #1857
TCarlson777's Avatar
Rcgearhead.com says around a 29 pinion, non boosted. Check temps after a few minutes.
TCarlson777 is offline
Old 04-08-2012 | 05:02 PM
  #1858
idrummerboy13's Avatar
Default wires
i tried hard on this shot!
ganna try stock springs and oils..all that is different is the front pistons a red 56 losi....
idrummerboy13 is offline
Old 04-08-2012 | 05:17 PM
  #1859
I drove my B44.1 for the first time this weekend and all I can say is Wow!! I was pretty happy with it overall, I just need a better selection of front tires and and play with shock oils then it should be money! I'm very happy this class is making a comeback in our area, this thing is a blast to drive.
Has anyone tried suburb front tires on indoor clay with good results? I ran scrubs and Panther bobcat fronts but I still wanted a little more steering.
nhraman is offline
Old 04-08-2012 | 05:19 PM
  #1860
mrplease's Avatar
what pinion should i run with a 5.0 turn motor?
i know different tracks require different pinions but whats a good starting point?
mrplease is offline
