B44.1 Thread
#1081
i bent a shock shaft though. i landed on a 4x4 SC that just stuffed it into the pipe. i didn't even realize it was bent until i finished practicing. oh and the plastic that holds the orings was slightly cracked as well. overall, it's been a solid buggy after 2 race days.
#1082
Little Help.....
So If I purchase the J Concept Blue Hexes for the B44.1 I can then run the TLR 22 wheels on the rear of the B44.1 with the correct off-set
http://www.jconcepts.net/store/index...roducts_id=524
Or do I need to purchase the JConcepts Inverse wheels #3338 (white) #3338Y (yellow) or Mono wheels 3348 (white) 3348Y (yellow) wheel for proper mounting, offset?
Thanks,
E
Thanks,
E
#1083
Little Help.....
Thanks,
E
Thanks,
E
I use these.
http://www.deracing.net/store/index....product_id=199
#1084
Registered User
Little Help.....
Thanks,
E
Thanks,
E
#1086
#1087
Just thought I would share this V2 info with the B44.1 gang as well.
http://www.rctech.net/forum/10130556-post6152.html
#1088
Thanks for sharing and please get back to us how you like them! I see the only benifit is to not have to rebuild with new rings as offen?
#1089
#1090
I currently build my shocks with a standard AE o-ring up top and either a kyosho, trinity or mcmaster carr grooved o-ring on the bottom and the white spacer, with a nice amount of green slime. Smooth as silk and no leaks.
#1091
I agree. It will be a few weeks but I will let ya know. Now we have some increments to work with. Based on a set ring and spacer. The seals I took out were clearly swollen to the point they were sticking unless I pumped them up. 6 weeks and 2 practice nights are a good run on any shock seal in my opinion. Hoping to get 8 with this method.
#1092
What are you guys using for front and rear tires?
Track I race on is a damp Clay surface I was using the stock tires but found a crack in the front rims and was going to get a new set and try some different ones out.,
Flipouts?
Barcodes?
Holeshots?
Rebars?
Flipouts?
Barcodes?
Holeshots?
Rebars?
#1095
1Likes
