Like Tree5Likes
SC10 4x4 Thread
Old 03-28-2012 | 12:28 PM
  #20236
Evil Genius jr.'s Avatar
The blue ones might work. I have some of the silver ones but it takes 10! per side to get to 5mm.
Evil Genius jr. is offline
Old 03-28-2012 | 12:32 PM
  #20237
heavyjeffd's Avatar
So this weekend I raced at the Dialed Inc Invitational in Shreveport, LA.
The track was pretty simple (due to bad weather the layout wasn't finished until 10pm Friday night) but because of the dirt used (river clay) it was hellaciously bumpy and hard on tires (the balder they were, the better they worked).
There were only a few small doubles, but a fair amount of elevation changed and this track was WOT everywhere with laptimes for SC being in the high 20's/low 30's.
Overall I was pleased with the SC10. I qualified 7th in the A in a field of about 40+. The little truck was bouncing all over the place, all you could do was pin it full wood and hope it levels it back out, which is pretty much what I did.
The A Main had 12 trucks in it, the top 3 were what I call "cheater" trucks (converted 1/8th scale buggies), then a bunch of SCTE's, and me (I was the only SC10 there). With a track that fast, if you caught a pipe or an edge you had half the field pass you. I THINK I finished 6th, I don't know for sure because I couldn't hear anything and they *still* have not posted results.
All in all though, the little truck is getting better. The Exotek has made the biggest difference by far, it completely transforms the truck.
I'll be running it in two weeks at the JConcepts Spring Indoor nationals along with 4wd and 2wd open buggy. That should be a better environment for it.
heavyjeffd is offline
Old 03-28-2012 | 12:57 PM
  #20238
Cain's Avatar
I used whatever I had in the pit box as I agree that a bunch of those little shims can be a bit much and they like to slide all over the place.
The nice thing though is that the space available in the ball stud area is such you can run a wider shim if needed. I think the shim I used was actually a spacer used on the rear of 1/8 buggy for the rear hub carrier. this was good for about 3mm, used 2 of those and a 1mm shim.
I wonder if a front alloy chassis could help even more, heck, maybe the whole thing?
Personally, I don't mind the 1/8 scale stuff I guess as if it fits in what the rules for the class are, its legal to me. Probably would be a non-issue if the tracks these days that we run this stuff on weren't 1/8 scale sized.
Cain is offline
Old 03-28-2012 | 01:17 PM
  #20239
heavyjeffd's Avatar
It's usually on the bigger tracks with bigger jumps and ruts, etc. where the conversion trucks just dominate because of suspension, chassis and drivetrain mostly.
On small tracks you are right, it's not much of a advantage.
Old 03-28-2012 | 01:48 PM
  #20240
Cant wait to get me a "cheater truck"
rickybobbyxxx is offline
Old 03-28-2012 | 02:18 PM
  #20241
kjohnsiii's Avatar
Got the FT done late last night. I am starting out with the Kody Numedahl set up. It calls for front and rear yellow springs however, I cant get the ride height set to 24mm front and back w/ the body off. I'm as low as it will go.
kjohnsiii is offline
Old 03-28-2012 | 02:20 PM
  #20242
Are the batteries in? Mine can go to 17mm.
Old 03-28-2012 | 02:23 PM
  #20243
Well I just ordered the factory team front and rear swaybars, shock mounting pins, wheel nuts and the high torque slipper pads.
My new rtr will be here tomorrow.
What other parts besides the battery conversion should I buy for it?
MattP is offline
Old 03-28-2012 | 02:27 PM
  #20244
kjohnsiii's Avatar
Yes the batteries are in..
Old 03-28-2012 | 04:16 PM
  #20245
Dam!!! Team ae got their ass handed to them at the cactus race in pro4, wow
Old 03-28-2012 | 05:18 PM
  #20246
Been working on the slipper (stock) pinned the front shaft and opened the hole in the rear slipper disk, it "should" now drive the front more than the rear instead of to much rear drive, will test it soon, anyone thought of this before the basket, ball diff etc? could be a simple fix?
RossNZ is offline
Old 03-28-2012 | 05:36 PM
  #20247
Cameron Kellogg's Avatar
Not enough rear drive is what the stock set-up gives you. The same thing RCShox has been working on with the V2 center diff. To much front drive will make the truck easy to drive but will be slower around the track in most cases. You will loose the ability to accelerate off corners and make larger jumps that most tracks are building in there layouts. This truck has more weight on the rear wheels than front. You will want more power or equal power to the rear than the front.
Cameron Kellogg is offline
Old 03-28-2012 | 05:40 PM
  #20248
DHooter's Avatar
hey guys when running a novak 4.5 what pinions should i buy when running on a 140x100 track? im thinking 12, 13,14.....
DHooter is offline
Old 03-28-2012 | 05:52 PM
  #20249
If the rear needs more drive then why have I not seen a single person run the underdrive pulley?
Old 03-28-2012 | 06:11 PM
  #20250
vito's Avatar
hows the brace from ae doing.?
vito is offline
