Team Associated RC8Be Thread
#7366
If anyone is interested I have some alum parts for the front end
http://www.rctech.net/forum/r-c-item...er-blocks.html
#7367
Ok, so here is my question,
I ordered ASC89491
http://www3.towerhobbies.com/cgi-bin...?&I=LXBGRK&P=7
and haven't installed it. Looking at it, it looks to be the same arm setup as the 8.2e along with the tower. What would be the minimum changes I would need to make to create something similar to the 8.2?
What I am envisioning is:
-89491 Sus. upgrade kit
-89476 +3mm chassis
-85929 Motor mount
-89560 Center shaft
Obviously the newer suspension parts are helpful, but I can get that later, just looking to get it up and running for now.
Will I also need:
-89238 Chassis Brace F
-89239 Chassis Brace R
-89552 Side Guards?
MOmo
I ordered ASC89491
-89476 +3mm chassis
-85929 Motor mount
-89560 Center shaft
Will I also need:
-89552 Side Guards?
MOmo
Only part you are missing is the Associated Low B Plate (ASC89481). This part is used to adjust front roll center and is optional. Stock B plate makes the car smoother and low B plate makes the car more aggressive.
I've done this conversion, but with the BCE chassis. The stock side guards and chassis braces worked.
#7368
Stay between 25 and 30wt Associated oils depending on how bumpy the track is. There is a big difference just going up or down 2.5 wt with the 10x1.1 pistons. These pistons are the way to go IMO.
#7369
Good to know. I should have the $$ to get the rest of the parts I need soon. I figured that there wasn't much difference between the 2. As much as i want to get an 8.2, cost wise, since I have a solid base, why not use it.
MOmo
#7370
Ok I'm new to the 1/8 and would like to get this kit from tower hobbies. As usual everyone has different opinions on what works and others. For racing what could be a good set up motor/esc, nothing too expensive just what will get the job gone. If my driving skills are good then later on fill go for the best set up but for now just want something reliable to put in and gave some fun in the track....any suggestions?
#7371
#7372
I built my first RC8e with a LRP SPX8 ESC and a LRP 2500KV engine. Whenever I turn on the toggle switch, the car runs full throttle without even touching my transmitter. What am I doing wrong here? All the wiring and soldering appear okay and my transmitter is on.
#7373
From LRPs manual:
TRANSMITTER SETTINGS
Setup the following basic functions on your transmitter (if available):
Description other names in radio Required Setting
Throttle Travel High ATV, EPA 100%
Brake Travel Low ATV, EPA, ATL 100%
Throttle Exponential EXP, EXPO start with 0
Neutral Trim SUB Trim center
Servo Reverse Throttle Don't Change after initial Setup
If your transmitter doesn‘t offer any of above functions, it‘s already in „basic setup“ mode.
• Ensure that the speed-control is not connected to the drive battery and is switched off.
• Remove motor pinion or ensure that the wheels of the model are free to rotate.
• Switch the transmitter on and set the transmitter throttle stick to neutral.
• Connect the speed-control to the battery and switch the unit on.
• Hold the SET button pressed for at least 3sec.
You entered setup mode and the SET LED flashes blue (it will flash until the setup is completed).
• Leave transmitter in neutral position and press the SET button once.
Neutral setting is stored , MODE LED flashes yellow and the motor beeps.
• Hold full throttle on transmitter and press the SET button once.
Full-throttle setting is stored, MODE LED flashes red.
• Hold full brake on transmitter and press the SET button once.
Brake setting is stored, LED‘s glow red (MODE) and blue (SET).
• This completes the setup procedure and your SPX8 is ready to use.
• If you make a mistake during the setup procedure, don‘t worry: Disconnect the battery for about 10sec and start
again from the first step.
• At the end of each run switch off the car, and then switch off the transmitter.
• At the start of each run switch on the transmitter first, then switch on the car.
• For storage of the car, disconnect the drive battery at any time!
See if that helps.
Manual found here: http://www.competitionx.com/pdf/esc/...esc-manual.pdf
MOmo
#7376
Hi Guys,
I just wanted to let you guys know that I'm going to be posting some rc8be parts up for sale...it will be a great way to get some spare parts pretty cheaply. I'll take some pics tonight and hopefully will be posting them tomorrow. PM me if your interested, thanks!
#7377
Here's a link for anyone who maybe interested...worlds towers included.
http://www.rctech.net/forum/r-c-item...l#post10390312
#7378
Anybody running the tekno v4 chassis right now? My rc8be is running great but I have seen the v4 in action and it looks like it handles sweet! I'm kinda bored with mine, thinking maybe I want to try something different. Any input on this?
#7379
hoping to get some answers here.thanx in advance...
in short.i picked up a rc8b and im converting it to a rc8be scte.
questions...
1-is there a motor mount that will fit the rc8b with a tekin pro4 (35.8 mm can)
2-is the snr graphite chassis durable.im looking to find one to cut weight.
questions...
