Team Associated RC8Be Thread >
Old 01-15-2012 | 10:14 PM
  #7336
TEXT's Avatar
Would it be possible for you guys to just put the part numbers needed andnot just post a website with all the parts there...i am only interested in the parts that would make the conversion successful haha ! Thanks a lot guys i can always count on rctech members to help me out and vice-versa !!
TEXT is offline
Old 01-16-2012 | 11:26 AM
  #7337
jmackani's Avatar
Up for sale if anyone is looking: http://www.rctech.net/forum/r-c-item...ce-roller.html.
jmackani is offline
Old 01-16-2012 | 11:27 AM
  #7338
jmackani's Avatar
Originally Posted by TEXT
By the way,
Can anyone link me to where I can convert my chassis to upgrade it to the RC8.2e? I heard all I need to do is change the shock towers, the new chassis, arms, and drive shafts but is that all I have to do? Just curious...I wouldn't know where to start looking...thanks a bunch guys!
Go back a page:http://www.rctech.net/forum/10131520-post7310.html
jmackani is offline
Old 01-16-2012 | 01:17 PM
  #7339
Mxer59's Avatar
Does anyone know the size of the tiny bearings in the steering assembly Id rather not spend 15 when I only need the tiny ones
Mxer59 is offline
Old 01-17-2012 | 01:19 AM
  #7340
Can I just use 8.2 arms with the RC8B "upgrade" towers and still keep the stock "b" shocks. I understand the upgrade towers are taller than the 8.2 parts that use a shorter shock...?
Lowrance is offline
Old 01-17-2012 | 06:46 AM
  #7341
Led Finger's Avatar
Default yup
Yes you can use the arms and yes the "worlds towers" are bigger. The only down side to sticking with the "b" shocks is you dont have the full benefit of all the extra droop the rc8.2 has..That being said us rc8.2 owners are finding out is that the extra droop is actually hurting the car..really it was fine the way it was on the rc8b(e). For me at least. There is alot of info on droop settings and all the other BS they shouldnt have changed (lower B plate) in the rc8.2 thread. Hope this clears up some things.
Led Finger is offline
Old 01-17-2012 | 09:37 AM
  #7342
hey guys finally got my RC8Be. It is used but in great condition and running on Tekin rx8 + 2050 motor. Have been driving around on a indoor parking lot to test it out (weather has been rainy) and theres seem to be an issue with the reverse.
Not sure if its the esc or my radio but it will take me couple of tries to reverse. I can brake to a full stop properly but in idle position to reverse is spotty. any help?
spena is offline
Old 01-17-2012 | 10:14 AM
  #7343
Mxer59's Avatar
I'm running mine with diffs 5-5-2 but my car does not turn if I let off if I turn then roll on the throttle this car will turn quick, it's a different animal between being on the throttle or off. Is this normal for this car I used to run a HB Ve8 HHH
Mxer59 is offline
Old 01-18-2012 | 08:50 AM
  #7344
Mxer59's Avatar
I have some alum parts for a Rc8, rc8be I think they will also fit 8.2
INTEGY Steering blocks
INTEGY Castor blocks
Sell both for $60 together
Mxer59 is offline
Old 01-22-2012 | 02:58 PM
  #7345
Monteman's Avatar
Just a quick question about gearing. What would the optimal gearing be in this guy is running 4s Lipo with a MMM 1512/1.5Y 1800kv setup. Looking for something i can set and forget as far as tinkering with gearing. Doesn't need to be the fastest thing out there but i don't want to be wasting potential by under-gearing for this combo.
Monteman is offline
Old 01-23-2012 | 02:04 PM
  #7346
Default 4s rx8 leopard 4082 1600kv combo
so im waiting for my rx8 to show but im curious what settings to run for my esc i have a hotwire already. im planning on running anywhere from a 16-21 pinion and im open on the spur. im not sure whats in there now as i just recieved the buggy as well. any suggestions on where to start for my timing and such???? i know in a boat they recommended 15 degrees timing!
help is much appreciated.
ANY OTHER TIPS ARE ALSO WELCOME!!!!
Snow4664 is offline
Old 01-24-2012 | 01:58 PM
  #7347
TommyT913's Avatar
Is there a specific upgrade "kit" to upgrade my RC8be to RC8.2e specs? I've been searching but can't find anything.
Thanks in advance for the responses.
Tommy
TommyT913 is offline
Old 01-25-2012 | 09:56 AM
  #7348
TEXT's Avatar
Tommy
Hey tommy,
I couldn't find anything either as far as an upgrade kit goes, but I did find all of the changes that they made, and did some comparisons as far as both manuals go. I compared side-by-side both manuals and typed out all of the changes. I got most of the parts...some of them aren't worth upgrading...ex. covers for the CVDs...thats just me though. I hope this helps!
http://www.rctech.net/forum/electric...-complete.html
As far as setup goes, I am running an RX8 1900kv motor with Venom 4s Lipo 5000mAH, it doesnt fit when I put the body on...OOPS! I have not ran the car yet because right now in time I haven't had the chance to take my car to an indoor track, and the nearest that allows indoor 1/8th scale is 2 hours or so away...bummer =/!!
TEXT is offline
Old 01-25-2012 | 11:06 AM
  #7349
jaybird95's Avatar
I'm thinking a 20t. I run a 19t on my 1900 with stock spur.
jaybird95 is offline
Old 01-25-2012 | 11:21 AM
  #7350
U guys sticking witj the plastic spur or running metal one and what size plastic spur should i run converting nitro. 2 to e going to run 1900 tekin witj mmp what spir pinion should start at thanms
jewn_beef is offline
