Team Associated RC8Be Thread
#7217
#7218
less downforce on the rear since it is lower.
If your track has fast sweeping corners, you will want the taller (RC8B) wing mount to increase downforce.
That is how I understand it.
good option to have both actually
#7219
Has anyone gone to a different wing than the stock RC8 wing? It keeps breaking in the same place, right beside the wing mount.
Also, anyone else find the stock rear springs to be very soft? I'm bottoming out on the lips of jumps at my local track ... thinking of going to the silver springs with 30wt oil.
#7220
I am running the J concepts Illuzion wing. It has taken quite a beating and retains its shape.
I forgot to add a bit of info about the shorter shafts for the 8.2, if you run the original shafts your will destroy the blatters on the first jump. As for springs, I am running the 8.2 springs on my worlds 8b (now 8be for the winter
) and they seem more consistant then my old springs, which were probably just worn out.
#7221
#7222
The 8.2 shock shafts are 2-3mm shorter.
#7223
And if I need to put a 3mm limiter on the outside of the shaft that wont kill me either ... I am all about the best bang for the buck here.
#7224
I just got one of these it's pretty much how it was out of the boxes. The guy before me drove it maybe 5 race days. I notice something is botteming out should I put stiffer rear shocks
#7226
Alright I'll have to order some springs. My track is pretty rough couple big jumps I notice it on the rougher sections. Braking and acceleration bumps
#7227
I haven't gotten a chance to order silvers for myself yet but from what I have seen the stock rear springs are not a great setup. Maybe for bluegroove/smooth tracks with small jumps, but not for large kickers and rough offroad tracks.
#7228
Question ... has anyone adapted the RC8.2e mudguards to work with the RC8e arms? I am tempted to just drill holes in the arms and buy a pack of those mudguards to bolt on. Seems like a nice touch to keep some of the dirt out of the rear outdrive/shock area.
