RC10B4.1 FT/WC
Old 02-28-2012 | 08:29 AM
  #12076
awesome so everyone is happy now
off to a meeting (hate that work thing lol)
Bob Barry is offline
Old 02-28-2012 | 08:33 AM
  #12077
brent701's Avatar
Originally Posted by STUBYSLAP31
I DID SEARCH..... I FOUND YOU NEED TRAXXAS OR RPM PART, 22 SHOCK RETAINER AND GHEA COLORS WHICH I COULDN'T FIGURE OUT WHY I NEEDED THE TRAXXAS OR RPM PART.... SORRY FOR ASKING A QUESTION...
Traxxas #3768 if you do not use the GHEA collars
Losi TLR5095 for the lower cups
brent701 is offline
Old 02-28-2012 | 08:37 AM
  #12078
STUBYSLAP31's Avatar
brent, thanks
STUBYSLAP31 is offline
  #12079
nismomike's Avatar
Hey Brent I was wondering what I need to run the Losi BB springs on my RC10 graphite buggy from 1989?
nismomike is offline
Old 02-28-2012 | 08:54 AM
  #12080
surgical team.
to remove Brent's foot from your ass
Old 02-28-2012 | 08:59 AM
  #12081
Kurt04's Avatar
Now since the TLR5095 is out of stock everywhere i could find. Has anyone came up with a new solution?
Ive thought about using the the Traxxas collars on the bottom as well with the Associated 9724 Offset Cups. Problem I could already see is that you're raising the lower cup when you already have a pretty short space for the longer spring.
You could cut/sand some off the top of the shock eyelet so the cup sits lower but with less threads you risk pulling the shaft out.
Kurt04 is offline
Old 02-28-2012 | 09:00 AM
  #12082
Default gearing ?
whats a good gearing for 17.5 boosted? ill be running my d3 17.5 with lrp sxx v2 for medium size high bite clay like ocrc size.
thanks,D
derbrylac is offline
Old 02-28-2012 | 09:02 AM
  #12083
nismomike's Avatar
Originally Posted by Bob Barry
surgical team.
Brent just text me and said all i needed to convert was a B4.1 W.E. , losi spring cups, traxxas spring retainers, and a cucumber. I'm just not sure about one thing and that is, what are the traxxas spring retainers for? He said the cucumber has something to do with anti-squat lol.
Old 02-28-2012 | 09:03 AM
  #12084
racer1812's Avatar
Super Moderator
They're a tight fit but simply using the Traxxas lower cup does work.
racer1812 is offline
Old 02-28-2012 | 09:14 AM
  #12085
Kurt04's Avatar
That makes sense.
Kurt04 is offline
Old 02-28-2012 | 09:15 AM
  #12086
nismomike's Avatar
Not sure if anyone else is running into this problem but in AZ it is literally impossible to find the Losi spring cups for the 22 BB conversion. So I have found a decent alternative for people who just cant wait. I bought some of the older Losi spring cups like the ones found on the XXXT part #LOSA5079, and then I bought 4 of the TRA3768 shock collars. The spring cups are just slightly smaller than the 22 cups, so I took a razor blade and split the traxxas collar so I could fit it over the spring cup. Then I super glued the traxxas collar to the spring cup and cut the shaft opening the same size. Spring sets on it perfectly. Fits the AE shock end perfectly. Obviously its easier to use the Losi cups, but they are M.I.A. Out here. I will post a pic in a minute.
Here you go. They are actually lower profile than the losi cups.
Old 02-28-2012 | 09:25 AM
  #12087
Blue Screw's Avatar
BIG wins... sorry there chassi slapper... but im over that point i rather help others from what was showed to me.. but then there hardhead knuckle heads like ur self who just wont listen... or take advise...like glueing servo savor..hmmmm..
And sorry to put u on blast but
REMEMBER I FORGOT MORE THAN U KNOW!
Originally Posted by SpraydbySprague
Sooo, who's the SOB costing you big wins now?
Sorry, couldn't resist! LMAO!!!
Hi, Angelo!
Yea, Mr Barry has been havin some bad luck. If it's got tires or wires, he's wrecking it!
I also pointed out the idea of cleaning the ESC case out to help remedy the button issue. I'm actually surprised how much dirt can actually build up in those little cases.
Blue Screw is offline
Old 02-28-2012 | 09:35 AM
  #12088
Hi Guys,
For those of you running Losi springs; it seems the lowest I can get the front ride height to is 25mm. I have the collars adjusted all the way up and I’m using the traxxas collars over the stock threaded collars and Losi spring cups. Am I doing something wrong or is this par for the course?
Thanks,
Jose
ittjv is offline
Old 02-28-2012 | 09:58 AM
  #12089
Originally Posted by ittjv
Hi Guys,
Thanks,
Jose
I actually trimmed the shock ends down when I had the same issues and it solved all of my problems. You can take 1-2mm off and still screw them all the way in without any issues.
Kave is offline
Old 02-28-2012 | 10:00 AM
  #12090
thanks,D
I know you say boosted but I run 17.5nt at WCRC and gear it at 72/33 and it's plenty fast.
jamr1130 is offline
