RC10B4.1 FT/WC
Hey guys just wanted to pass this on. I just bought a worlds B4.1 kit from Moore Hobbies on ebay. The listing said to call for a discounted price so I did and he gave me a promo code of ebay on moore hobbies website so I punched it in and got $10.00 off and got it for $244.99 shipped. www.moorehobbies.com check it out.
Grats on the trophy Guy, it was a fun race. At least the last few laps was clean, LOL! I still feel horrible about what happened 13 seconds into this vid.
| + YouTube Video | |
I've done it. I have not seen a "huge" difference, nor will I say it was worth the money to convert. It's just a different feel. A little smoother here and there. I personally just like them bc they don't rub the shock bodies and they are a little longer than stock ae springs so it takes less preload.
...exactly! You have to let the turnbuckle be the conductor in the simple green. Dont let the wire on your t/b in the fluid. Wrap the threads, dunk the majority of the rod and wait until you get the desired color. Take it out, flip the wire to the other end and dunk the remaining untreated part of your t/b.
The shade of color will vary by the length of time you soak it.
ps- I used alligator clips. Makes the job even more simple!
Any of you ever had a problem keeping your spur gear from wobbling? I installed new gear, new slipper and pads, new bearings inside of case, new spring and washer and nut. No luck. I did not change the top shaft, but I just really don’t think it could be bent. To be honest I don’t think the spring sits square on the slipper plates. Almost as if un even pressure is being applied to the slipper. Any thoughts?
Hey guys, got the Losi BB springs on my B4.1 and I love them for sure.. however I have one problem. The ride height in the front is too high. I'm using the traxxas collars and the springs are at full extension. I'm running the orange up front and pink in rear.. pretty planted for the track I run at.
27.5 oil in front and 30 rear.
I'm sure its something obvious I'm missing, are people compressing them a good bit before using?
(Or just get the GHEA ones)
On a side note..... I did some of the anodizing of the Titanium turnbuckles as posted a page or so back.
I'm using the #2 pistons and my turn in was a joke because my ride height was higher in the front than the rear.. still better than AE springs though so I can't complain.
has anyone tried to do a "darker" blue then the stock because every chart i see is ~54v (six 9v) for a light blue, or ~108v (twelve v9) for a darker blue.
mostly want to try to get my racers edge hubs blue
think im going to try tonight
Thanks for the info... I think I may hold off on it and focus on some other things for now. Ive always been a sc guy so I need some guidence on buggy setup, please bear with me haha:
- What spacer(s) should I be using for a spectrum servo? Im not running any right now, but im not sure if that is right.
- At the track I ran at, the owners wife was taking pics and in all the pics my buggies front end is dipping down in the turns and on the jumps, is that supposed to do that?
- My buggy was pushing extremely bad through the turns, would the above issues cause that? Ill attatch a few pics to show what im talking about.
Current setup is 30wt front, 25wt rear with the pistons in the assembly bag (not the ones on the parts tree), 0* front toe, 2* camber front
