Like Tree5Likes
SC10 4x4 Thread
Old 02-02-2012 | 11:22 PM
  #16486
CoyoteSlash's Avatar
Originally Posted by Mizchief
Agreed. Only issue is that once you switch, you have to undo your setup for working around the poor power distribution with the stock setup. Like no more 30k diff fluid up front, etc.
I'm still running the front yellow springs/sway rear blue spring/sway and tweaking it out to remove some of the push. Half my problem was that my dumbass was running overdrive front pully by accident, once I fixed that, I just needed to add a little camber up front to help the wheels bite a little more on the slick clay I was running on. I'm playing with diffent shock mount settings now to remove some rear weight transfer prior to switching to yellow rears.
I had Diffs built up for the pinned mod and unpinned mod for tuning to the track. It'll be no problem. Good point though.
CoyoteSlash is offline
Old 02-03-2012 | 07:05 AM
  #16487
Chad Smith's Avatar
Anyone run these saddles?
http://www.hobbyking.com/hobbyking/s...ddle_Pack.html
Im curious to see how they fit inside of the b44 saddle tray, are they to tall?
Chad Smith is offline
Old 02-03-2012 | 07:17 AM
  #16488
Slotmachine's Avatar
I run those very same batteries and they are a perfect fit. The ones that are a problem are the 6000`s from Gens Ace.
Slotmachine is offline
Old 02-03-2012 | 07:26 AM
  #16489
Cain's Avatar
can you elaborate on what exactly is the problem with the taller Gens Ace?
Is it that there is not enough room for them to fit under the tunnel, or, is it that the battery tray posts don't go high enough?
Cain is offline
Old 02-03-2012 | 07:30 AM
  #16490
cbaranski's Avatar
I run the saddle conversion on mine. I use the Gens ace 6000. I run this with the Reedy Sonic 6.5 540 and can run a 15 min main with them.
cbaranski is offline
Old 02-03-2012 | 07:32 AM
  #16491
Cain's Avatar
shot a message to exotek to see if there are any issues with running taller lipos with their inline conversion.
Also, since there probably are a good amount of people in the know here concerning my question, please take a look at this thread:
http://www.rctech.net/forum/radio-el...-vs-reedy.html
Cain is offline
Old 02-03-2012 | 07:43 AM
  #16492
Originally Posted by CoyoteSlash
Main website - Setup sheets. Dunno how you didn't find it. Not a problem, man.
Thank you.......I did see that but did not put 2 & 2 together
Thanks again
Triple B is offline
Old 02-03-2012 | 07:44 AM
  #16493
Originally Posted by F_ME
Best get to reading. Lots of good info in the thread. Start on page 1.
That is where I started with my RTR.
I have been there for hours......there is a lot to process
Triple B is offline
Old 02-03-2012 | 07:47 AM
  #16494
CraigMBA's Avatar
I took me three days' worth of evenings to get through all of it---back in July.
CraigMBA is offline
Old 02-03-2012 | 07:49 AM
  #16495
JEFFs SC10's Avatar
Originally Posted by MantisWorx
im leaving the house at 5:30 PUNK!! at least that is the plan anyway.
Make sure to get some vids, I wanna see this!
JEFFs SC10 is offline
Old 02-03-2012 | 07:52 AM
  #16496
Originally Posted by vito
will you have a parts kit to up date the old one with all the new parts in one bag or box?
Unfortunately there won't be an upgrade kit.
eta on the new ft parts ty?
Seeing as how they were just announced, I don't think you will see them for a few more weeks.
Originally Posted by JEFFs SC10
Hey Jarosz,
Howd you like the Reedy race?
It was a ton of fun! Always my favorite race of the year!
Chris Jarosz is offline
Old 02-03-2012 | 07:54 AM
  #16497
It is worth the read as there is a wealth of info here. But don't forget the search feature. It's not the best but at least gets you closer to what your looking for.
jamr1130 is offline
Old 02-03-2012 | 07:55 AM
  #16498
Chad Smith's Avatar
How did you fit the battery strap in there with the Gens Ace 6000's. I am running the 6,000's now and its so close to the belt tunnel I dont see how the strap would fit.
Old 02-03-2012 | 07:57 AM
  #16499
Chad Smith's Avatar
Ok thanks for the reply. How is the runtime with these packs?
Old 02-03-2012 | 08:29 AM
  #16500
You can run the taller GensAce 6000Mah saddle lipos. The straps fit fine and do not hit the belt cover. All you have to do is run a spacer and or small nut to raise the battery post. I then locktite the threaded stud into the thumb screw so that they unscrew as one. I run the battery post with the hex on top so I can remove the two left hand posts with small nut driver. It is necessary to remove the two posts to remove the two saddle packs. I usually leave them in and charge in the truck.
F_ME is offline
