Serpent 811E Buggy Thread >
Like Tree5Likes
Old 01-22-2012 | 07:58 AM
  #1291
porkchop's Avatar
Originally Posted by Linkdead
Conical pistons or stock?
conical on a bump to tight track.
big air there a white flat piston out for when you feel the car jumps to flat on the conical piston
porkchop is offline
Old 01-22-2012 | 11:53 AM
  #1292
Default Weight
what is the weight as roller?
Magnus F is offline
Old 01-22-2012 | 12:41 PM
  #1293
Cmjomaha's Avatar
Finally starting my build today and have a couple quick questions. I am using the anti-squat plate RR FR 2.5 - 4.5 (#600308) and the LRC RR RR LR 3
(#600267). Any idea on where to start with inserts??
Cmjomaha is offline
Old 01-22-2012 | 12:54 PM
  #1294
porkchop's Avatar
in the toe plate 6 insert gives you 3 degs
but since it low roll center it add 1 deg squat to your car as soon as you bolt it on so now your plate is a 3.5 to 5.5 plate
i been wanting to try the lrc block with a 6
stock anti squat insert with a 5 up insert
porkchop is offline
Old 01-22-2012 | 01:54 PM
  #1295
Frank L's Avatar
Originally Posted by batremi
thank u Frank. does the eight hole come in the kit or is it an option part. also im about to order the fironi alumn pistons . this means i can use lighter fluids and still have enough pack when landing of big jumps?
The 8 hole conical are option parts.
Frank L is offline
Old 01-22-2012 | 02:02 PM
  #1296
Frank L's Avatar
Originally Posted by rcq
How do you can drive this buggy with hubs forward. With it buggy rear end is very slipping for me. And I use thinner swaybar for front end and tighter swaybar for rear end. When I try thinner foward swaybar I get more stearing on high speed.
What you could surgest for me for better handing for rear end of buggy. Now I run with 5 5 3 diff oil, maybe 5 5 1 would be better?
You need to consult the hudy setup guide
wheels closer together
more rear traction
weight shifted to back
wheels farther apart
slightly more steering
better stability
weight shifted to front
So to move the rear hubs forward will tighten up the rear.
Frank L is offline
Old 01-22-2012 | 02:09 PM
  #1297
Cmjomaha's Avatar
Thanks, so just so I got this right...the LRC Toe Plate will add 1 Deg squat? and since I would be using the 2.5 - 4.5 inner squat it would then be increased to 3.5 - 4.5. This is assuming I would be using the 0 insert? Sorry for the slowness, still trying to get a good understanding and a good starting place...
Thanks again...
Cmjomaha is offline
Old 01-22-2012 | 03:58 PM
  #1298
[QUOTE=rcq;10204491]How do you can drive this buggy with hubs forward. With it buggy rear end is very slipping for me. And I use thinner swaybar for front end and tighter swaybar for rear end. When I try thinner foward swaybar I get more stearing on high speed.
What you could surgest for me for better handing for rear end of buggy. Now I run with 5 5 3 diff oil, maybe 5 5 1 would be better?[/QUOTE
Sway bars are a minor adjustment, but if you want to mess with them you need to remember how weight transfer works. More weight transfer =more traction and less weight transfer = less traction. If your going to run a fatter sway bar on the rear of the buggy, your reducing weight transfer which reduces the rear traction. Thin= more weight transfer which = more traction. You would be better off switching those bars around, however remember sway bars are a fine tuning option. Start with tires, springs, and rear toe in. Running softer rear springs or increasing your rear toein is going to have a more drastic change on your traction. Also focus on one end of the car. If you need more or less rear traction, make adjustments on the rear of the car. If you need more or less traction in the front, make adustmens to the front. I recommend picking up the XXX Setup Guide. It explains the physics behind the changes you need to make.
400units is offline
Old 01-22-2012 | 04:02 PM
  #1299
porkchop's Avatar
Thanks again...
0123 are front inserts only
456 are for the rear
i see if i can get jared to post the chart or some can help you lost me
porkchop is offline
Old 01-22-2012 | 04:11 PM
  #1300
minit76's Avatar
This should be the insert positions to obtain the rear toe and ant-squat.
Toe:
4 in = 2 degree toe
5 in= 2.5 toe
6 centered is 3 deg
5 out = 3.5 toe
6 out= 4 toe
Anti:
4 down = 0 anti
5 down= . 5 anti
6 centered = 1 anti
5 up is 1.5 anti
4 up = 2 anti
2.5 -4.5 option anti-squatplate:
4 down = 2.5° anti
5 down = 3° anti
6 center = 3.5° anti
5 up = 4° anti
4 up = 4.5° anti
minit76 is offline
Old 01-22-2012 | 10:01 PM
  #1301
Cmjomaha's Avatar
Toe:
4 in = 2 degree toe
5 in= 2.5 toe
6 centered is 3 deg
5 out = 3.5 toe
6 out= 4 toe
Anti:
4 down = 0 anti
5 down= . 5 anti
6 centered = 1 anti
5 up is 1.5 anti
4 up = 2 anti
4 down = 2.5° anti
5 down = 3° anti
5 up = 4° anti
4 up = 4.5° anti
thank's so much!!! Sorry for confusing you chop, but I think I finally got it.
Cmjomaha is offline
Old 01-22-2012 | 10:09 PM
  #1302
porkchop's Avatar
ok just rember when you use the lr rear block it makes 1 deg of squat in the car. so take note into that.
thanks mr weber for the insert list
porkchop is offline
Old 01-23-2012 | 04:24 AM
  #1303
is there a parts list anywhere of what would be needed to convert a nitro version 811 to the BE version? I have 2 complete rollers and a ton of spares, looking to convert 1 to a BE.
ShagNastyEk9 is offline
Old 01-23-2012 | 09:14 AM
  #1304
porkchop's Avatar
it cost as much to almost buy a car
porkchop is offline
Old 01-23-2012 | 04:06 PM
  #1305
i find that very hard to believe considering it has the same suspension, steering, shocks, diffs, etc as the nitro buggy
