Max Power RP3.5 Racing Edition .12 engine
#16
Hi
I'm wondering how the two named engines perform. Is there anybody who has already tested these engines?
Also the carb in plastic, is it the way to avoid restart problems? On the other hand the Max RP3.9 has an alloy carb.
Thanks for your input.
Greets from Switzerland
#17
Max still use the low end 11.5 mm Nova plaform for their engine. Nova Keep On uses the new 11.9mm platform, with longer stroke, new main bearing size, higher carb volume, lower fuel consumpion, narrower venturi duct. Keep On claims with higher bottom end torque, better fuel conumption on 11.9 platform.
Thank you for the reply.
What about the Max RP3.9? This engine also offer a 11.9 platform. What is your opinion, would the Nova anyway perform better than the Max? Important for me is the easy tune of the engine and bottom power. Low consumption is also a point which is important for me.
#18
Te larger the diameter the more rotating mass off center and that is no gain.
There are 2 gains, the 1st one is that the crankshaft will get stronger without special hardening processes and the 2nd one is that working with the same tolerances you will get a smaller window on differences in timing during production series..
#19
It also still has the short stroke design which is originally from 2005.
So wouldn't bother too much with everything Nova claims, performance on the track is the only thing that counts.
#20
if red is good how is your grey going i think i read some were you were changing the colour if i listen to lars// if it is not red it won't go but i am only a mugen driver so what would i know hope you are having fun with your racing because we are it makes lots of fun to have a dig at other brands so i hope now one takes any thing said out of text////greg
#21
The fastest .12 engine currently available, the Orcan GT3, still has an 11,5mm crank.
Which GT3 are you talking about, there are 3 types on the market I've seen.
The GT3, GT3-S and GT3-C. S for small to mid size tracks and C for high speed tracks.
What is your opinion of the Max RP3.5? Or would I go better with the new Nova Keep On?
#22
I haven't seen any of the new Max or Nova engines on the track yet but to be honest I've never been impressed by the engines from either brand.
#23
The GT3 is the 2011 model. For 2012 Orcan has released the GT3-S and the GT3-C. Like you said the S has more torque and is more suited for smaller, technical tracks and the C has more top end power and is more suited for big, open tracks.
I have read the report of Dirk Wischnewski's race in Thailand at the pre world. They said, that the GT3-S was better and easier to drive as the GT3-C and also the fuel consumption was much less as with the C Spec. My question is, how much could be the difference in the top end of the two engines.
#24
Thank you for your reply DS.
That's really hard to say, I personally haven't tested both engines yet. I'm guessing between 3-5km/h but that's pure guess work based on my findings when I adjust the timing of an engine using liner shims.
