Old 02-27-2012, 07:30 AM   #16
Originally Posted by Italboy View Post
Hi
I'm wondering how the two named engines perform. Is there anybody who has already tested these engines?
Also the carb in plastic, is it the way to avoid restart problems? On the other hand the Max RP3.9 has an alloy carb.
Thanks for your input.
Greets from Switzerland
Max still use the low end 11.5 mm Nova plaform for their engine. Nova Keep On uses the new 11.9mm platform, with longer stroke, new main bearing size, higher carb volume, lower fuel consumpion, narrower venturi duct. Keep On claims with higher bottom end torque, better fuel conumption on 11.9 platform.
GP: Capricorn C03 1/10 touring, Capricorn C803 1/8 onroad
Engine: Tesla .12 WC, Tesla .21 7 port on-road, Rody VS02, OS 2101
beebone is offline   Reply With Quote
Old 02-27-2012, 08:43 AM   #17
Hi beebone
Thank you for the reply.
What about the Max RP3.9? This engine also offer a 11.9 platform. What is your opinion, would the Nova anyway perform better than the Max? Important for me is the easy tune of the engine and bottom power. Low consumption is also a point which is important for me.
Italboy is offline   Reply With Quote
Old 02-27-2012, 10:54 AM   #18
Roelof's Avatar
Send a message via ICQ to Roelof
Why is the 11.5 mm crankshaft low end? Let me remind you that the MAX .21 version with a 14mm crankshaft has many titles on his name against the superb (??) 14.5mm crankshaft.
Te larger the diameter the more rotating mass off center and that is no gain.
There are 2 gains, the 1st one is that the crankshaft will get stronger without special hardening processes and the 2nd one is that working with the same tolerances you will get a smaller window on differences in timing during production series..
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 02-27-2012, 07:14 PM   #19
DS Motorsport's Avatar
The fastest .12 engine currently available, the Orcan GT3, still has an 11,5mm crank.
It also still has the short stroke design which is originally from 2005.
So wouldn't bother too much with everything Nova claims, performance on the track is the only thing that counts.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 02-27-2012, 10:02 PM   #20
Default red
if red is good how is your grey going i think i read some were you were changing the colour if i listen to lars// if it is not red it won't go but i am only a mugen driver so what would i know hope you are having fun with your racing because we are it makes lots of fun to have a dig at other brands so i hope now one takes any thing said out of text////greg
greg.dawn is offline   Reply With Quote
Old 02-28-2012, 11:33 AM   #21
Hi DS
Which GT3 are you talking about, there are 3 types on the market I've seen.
The GT3, GT3-S and GT3-C. S for small to mid size tracks and C for high speed tracks.
What is your opinion of the Max RP3.5? Or would I go better with the new Nova Keep On?
Old 02-28-2012, 12:40 PM   #22
Hi DS
The GT3 is the 2011 model. For 2012 Orcan has released the GT3-S and the GT3-C. Like you said the S has more torque and is more suited for smaller, technical tracks and the C has more top end power and is more suited for big, open tracks.
I haven't seen any of the new Max or Nova engines on the track yet but to be honest I've never been impressed by the engines from either brand.
P1-RC.com
Old 02-29-2012, 01:03 PM   #23
Thank you for your reply DS.
I have read the report of Dirk Wischnewski's race in Thailand at the pre world. They said, that the GT3-S was better and easier to drive as the GT3-C and also the fuel consumption was much less as with the C Spec. My question is, how much could be the difference in the top end of the two engines.
Old 03-01-2012, 01:37 PM   #24
The WC track looks pretty tight and technical to me so it makes sense they prefer the S version.
That's really hard to say, I personally haven't tested both engines yet. I'm guessing between 3-5km/h but that's pure guess work based on my findings when I adjust the timing of an engine using liner shims.
P1-RC.com
Old 03-30-2012, 01:30 AM   #25
Arahawak's Avatar
Trader Rating: 32 (100%+)
Any kind souls here can help?
What is the Max pipe equivalent to the Nova 2660 for .12 size and 2015 for the .21 size ??
Thanks in advance.
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 05-20-2012, 07:01 PM   #26
Osiris 75's Avatar
Trader Rating: 17 (100%+)
Anyone notice the rod issues on these engines?
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
