Like Tree5Likes
SC10 4x4 Thread
Old 12-27-2011 | 11:58 AM
  #13171
SourDieselX's Avatar
just use threadlock to keep the pinion screw in.
SourDieselX is offline
Old 12-27-2011 | 12:04 PM
  #13172
lodhammerdin's Avatar
@ craigmba
Will you ever shut the hell up and quit being a dick?!?!?!?! So what if someone make a mistake, no body is perfect, including you ya FU*KSTICK!!!
Please stop trolling and stay out of this thread... Your the reason that all the drama gets started.
Now... go ahead and flame away... you too coyoteslash, your his little minion in his game...
lodhammerdin is offline
Old 12-27-2011 | 12:07 PM
  #13173
If you have to use thread lock to keep a pinion on, there's a problem. Just put the pinion on, tighten it, set your gear mesh and put the truck on the ground, give it a couple pulls of the throttle, then, recheck your gear mesh and snug the pinion set screw and motor screws down again. Never had a problem in 20+ years of RC racing.
Old 12-27-2011 | 12:13 PM
  #13174
Originally Posted by lodhammerdin
I drilled a small hole in the chassis directly under where the pinion set screw should be. I never have a problem. and befor that, I just used this:
http://www.amainhobbies.com/product_...iver-5-64-Blue
thats what i was thinking a drill a small hole. thanks
Graphite07 is offline
Old 12-27-2011 | 12:17 PM
  #13175
not a problem man. I used a pair of calipers to measure my wrench's shaft width and found the smallest bit possible. Also, its small enough so that dirt isnt an issue of getting under the under tray.
Old 12-27-2011 | 12:24 PM
  #13176
Wild Cherry's Avatar
Lod , woops ...
yeah
meant the 5/64th for the pinion , aaaah geeesss ...
Wild Cherry is offline
Old 12-27-2011 | 12:27 PM
  #13177
No tricks , I just use my 3/32" and tighten the pinion down .
1/16 for the pinion i just installed and 5/64"
Old 12-27-2011 | 12:28 PM
  #13178
sandsurfer's Avatar
any one have a trick to get the pinion on tight? i can't seem to get a allen in to get the set screw tight. my pinion has come off twice now. the truck runs good got the binding issues fixed. but i am going to take it back apart because i just read about the diffs not having enough fluid in them.
Pull the motor, use the measurement in the manual, tighten pinion, then reinstall motor.
sandsurfer is offline
Old 12-27-2011 | 12:30 PM
  #13179
1/16 for the pinion i just installed.
48P pinions uses the 1/16th or 2.5m ....
don't quote me though ....
Old 12-27-2011 | 12:33 PM
  #13180
Lod , woops ...
yeah
EXACTLY MY POINT!!! You made a simple mistake, an error if you will, and he see's blood in the water!!!
He thinks that he is PERFECT and never makes a mistake and that when someone else does, its the end of the world. He just needs to get a life or just go kill himself...
Old 12-27-2011 | 12:40 PM
  #13181
jsamarin's Avatar
the problem with that is, 32 pitch 13 tooth and up (i think?) wont fit through the hole in the motor plate, so you have to install it while the motor is in the truck.
jsamarin is offline
Old 12-27-2011 | 12:45 PM
  #13182
that is correct, I just confirmed it on my truck. 32 pitch, 13t, 14t, 15t, 16t, 17t, 18t, 19t are all to big to fit thru the hole in the motor plate.
Old 12-27-2011 | 12:47 PM
  #13183
Default pinion depth
This worked perfectly for me with 13t/32 pitch pinion, on a castle 1410.
jzpilot is offline
Old 12-27-2011 | 12:50 PM
  #13184
jsamarin's Avatar
Originally Posted by jzpilot
This worked perfectly for me with 13t pinion.
maybe its the 14t that wont fit. I know my 15t, and 16t are much to big to fit.
jsamarin is offline
  #13185
CristianTabush's Avatar
That's so funny, I can get a 14t in my truck to fit through the hole...
CristianTabush is offline
