Like Tree5Likes
SC10 4x4 Thread
Old 12-27-2011 | 09:25 AM
  #13156
vito's Avatar
i like to get a cluch basket but i dont use pay pal.
vito is offline
Old 12-27-2011 | 09:28 AM
  #13157
any one have a trick to get the pinion on tight? i can't seem to get a allen in to get the set screw tight. my pinion has come off twice now. the truck runs good got the binding issues fixed. but i am going to take it back apart because i just read about the diffs not having enough fluid in them.
Graphite07 is offline
Old 12-27-2011 | 09:52 AM
  #13158
SCTDan's Avatar
I trimmed a little off the short end of an Allen wrench so it fits in easy and use blue locktite. Never had one come lose.
SCTDan is offline
Old 12-27-2011 | 09:57 AM
  #13159
Wild Cherry's Avatar
Tech Legend
No tricks , I just use my 5/64 thand tighten the pinion down .
Last edited by Wild Cherry; 12-27-2011 at 01:32 PM. Reason: gave wrong size for grub screw
Wild Cherry is offline
Old 12-27-2011 | 10:16 AM
  #13160
got mine for sale in the for sale section if anyone is interested comes with everything just needs a receiver and controller and your ready to race.
kevink123 is offline
Old 12-27-2011 | 10:52 AM
  #13161
jsamarin's Avatar
what i did was put the motor in the truck to get the pinion in the right place and snug it up the best you can, then loosen the motor screws almost all the way, so you can tilt the motor up. This allows you to get a good angle on the grub screw to get it nice and tight.
It might sound complicated, or time consuming, but it only takes a minute or two.
hey coyoteslash, do you have any chassis braces ready to go? might need to get one off you on payday this wednesday.
jsamarin is offline
Old 12-27-2011 | 10:56 AM
  #13162
CraigMBA's Avatar
Originally Posted by Wild Cherry
No tricks , I just use my 3/32" and tighten the pinion down .
CraigMBA is offline
Old 12-27-2011 | 10:57 AM
  #13163
CristianTabush's Avatar
If its small enough, tighten the pinion with the motor out of the truck. It will allow you to torque down more. Otherwise, use an "L" wrench to get in there.
CristianTabush is offline
Old 12-27-2011 | 11:07 AM
  #13164
Tech Legend
Coyote & Craig
Nice try bucky's....
Old 12-27-2011 | 11:18 AM
  #13165
CoyoteSlash's Avatar
I make batches at a time, unless it's an emergency. They'd be in the mail thurs. if ordered wed.
Coyote & Craig
The problem is... We don't have to "try", Buddy. =)
CoyoteSlash is offline
Old 12-27-2011 | 11:20 AM
  #13166
CraigMBA's Avatar
Coyote & Craig
I wanna see a 3/32" pinion setscrew. Pics or it didn't happen.
CraigMBA is offline
Old 12-27-2011 | 11:21 AM
  #13167
Tech Legend
Yes, you are both R trying to get on my goat again...
Have a fun ride ....
Old 12-27-2011 | 11:27 AM
  #13168
CraigMBA's Avatar
No way Jose. I just want to see the 3/32" set screw on the pinion.
Remember, you brought it up smart guy!
CraigMBA is offline
Old 12-27-2011 | 11:32 AM
  #13169
Tech Legend
Default 32 pitch pinion gear grub screw size
used the 3/32 just yesterday , however, just checked and the 2m is the actual size bucky ...
just may depend on the brand pinion ?
Yaw Who , ride um ...
Old 12-27-2011 | 11:58 AM
  #13170
lodhammerdin's Avatar
I drilled a small hole in the chassis directly under where the pinion set screw should be. I never have a problem. and befor that, I just used this:
http://www.amainhobbies.com/product_...iver-5-64-Blue
lodhammerdin is offline
