SC10 4x4 Thread
Ill start with my set up
-Tekin pro4 4000kv
-mmp w/bec
-62/12 32 pitch gearing
-clutch basket w/ garodisks
-20/20 pulleys, belt tension 3/3
-30k/7k diff oils
-I dont have the pin mod
-clicker is full time 4wd
There are a couple things that i cant figure out. First, my motor seems to run hotter than most that Ive seen in this thread, after 10m the motor is sitting around 175 degrees. Ive checked for binding and cant really seem to find any but the truck definately doesnt feel as "loose" as other sc10s ive driven at my track.
Second, I seem to chew up spur gears like crazy. I ran the truck for 6 months or so with the same spur that came with the kit but recently something changed and sometimes ill go through 1-2 spurs in a night. Ive had guys at the track check my gear mesh and it seems to be fine. I thought maybe my slipper wasnt slipping enough to i backed it off. No change. I took the basket off and replaced the garodisks with 1 hd pad and a standard just to see if that stops the problem but it didnt.
Third/Fourth, my truck makes this high pitch screeching noise on hard launches and on power out of corners. I sounds like the slipper but its MUCH louder than any other sc10 ive ever seen. you can hear it over every other sct and 1/8th scale on the track. It also make the knocking/clicking noise ive read about in this thread and I cant seem to track it down. Ive shimmed the diff and checked the assembly of the gear box, diff, idler gear and top shaft. All that looks right.
Whatever the issue is seems to be coming from the rear gearbox area, I just cant see anything wrong.
-Tekin pro4 4000kv
-mmp w/bec
-30k/7k diff oils
Hey guys, need some setup advice. I need alot more traction. My truck is loose coming out of corners like it is over rotating and also on sweeping turns my truck wants to spin out. It feels like I have to drive this truck like a 2wd buggy right know.
I also think it could be my chassis brace. Does taking away some of the flex have an effect on the traction or handling of the vehicle?
Try moving the bottom of the shocks furthest out. What is your ride height? What sways are you running?
Try dropping rear like 2-3mm and see if that helps any.
Do one mod at a time then take it out to see if it helps/hurt
I will not dispute the performance gain.
I will dispute it being 'better' than lead weights that can 'pop off'.
At the price it sits at for what it does and what you can do that attains the same results. 50.00 of those dollars "IS" Bling.
I have lead weight packed in around those ribs in the chassis, that I can't even pry out, and a chassis brace for 15.00+5.00(lead) = 20.00 performance increase over 110.00. This setup does 'not' account for torsional chassis flex and that is the only thing Exotek can claim to fame(besides looking damn good)
I believe that you will like the chassis.
I have learned
though many , many moons of racing r/c cars ........
The AE "Team"
Knows best how to make your ride HI-PO ..
So if your going to spend $$$ , look first at what they are doing with their rides.
Then consider your next investment in your quest for superior performance for your Rc10Sc4x4 ....
The AE "Team"
I'm 100% sure i'll love the chassis. That was never my point.
-Tekin pro4 4000kv
-mmp w/bec
-30k/7k diff oils
I think your under geared. Sweet spot for the 4000kv Pro4 seems to be between 15-17. The smaller the track the lower the gear. Under gearing can result in heat issues as well. I'd try starting with a 15 and see what you get. 175 for the Pro4 is not an issue if the performance is where you want it.
As for chewing up spur gears and that high pitch screeching noise, I'd recommend you loosen up your gear mesh. The first time I bench tested my setup it made a ton of noise, so I opened up my mesh and problem solved. Have you rechecked the front diff case housing? You can't over tighten those three bolts or you'll bing up the front end.
-Tekin pro4 4000kv
-mmp w/bec
-30k/7k diff oils
Be happy when I hear news of a FT version. Until then, I will just be content with my 2wd and watch everyone else sink serious $ in their rigs. Associated WILL get it right in the FT version, just watch.
The EA factory parts that are out now are just for bling.
These 3rd party parts are needed for the truck. Even Cav needs the 3rd party chassis brace and clutch basket.
5Likes
