Like Tree5Likes
SC10 4x4 Thread
Old 12-17-2011 | 03:30 PM
  #12676
Makarrov's Avatar
Originally Posted by JEFFs SC10
your high pitch sound definitely sounds like rear diff. time for a rebuild kit and adding extra shims. It's a giant p.i.t.a to get at but more than likely that is where your problem lies.
Ive torn this thing apart so many times looking for this problem Ive gotten used to the tear down lol.
I just bought and installed the diff rebuilt kit last week, the noise was still there last night when I ran the truck. Tonights project is to install the new top shaft, idler gears, diff case, belt, pullies and gear box that are sitting on my bench... Hopefully one of these things fixes it.
Makarrov is offline
Old 12-17-2011 | 03:36 PM
  #12677
vito's Avatar
look at the bolts that go in the gear case. not to long and hit the diff gear
vito is offline
Old 12-17-2011 | 03:44 PM
  #12678
JEFFs SC10's Avatar
wow man, i hated doin mine lol, took a good long afternoon but I was able to find some other things that I needed to look at in fix in the process.
That's weird, Did you double shim?. Check to see if you have a lot of belt dust. Check your motor mount plate. Something isn't meshing right (obviously)
JEFFs SC10 is offline
Old 12-17-2011 | 04:50 PM
  #12679
CoyoteSlash's Avatar
Originally Posted by SourDieselX
it's far more then just "bling," it's added weight, 5oz heavier versus stock, that beats having to use lead weights stickied to your truck, also gets rid of the possibility of one of those weights coming off. second, just about all flex is removed from the situation, meaning you don't need a chassis brace. I've had mine since they released them, love it and wouldn't look back.
I will not dispute the performance gain.
I will dispute it being 'better' than lead weights that can 'pop off'.
At the price it sits at for what it does and what you can do that attains the same results. 50.00 of those dollars "IS" Bling.
I have lead weight packed in around those ribs in the chassis, that I can't even pry out, and a chassis brace for 15.00+5.00(lead) = 20.00 performance increase over 110.00. This setup does 'not' account for torsional chassis flex and that is the only thing Exotek can claim to fame(besides looking damn good)
CoyoteSlash is offline
Old 12-17-2011 | 04:59 PM
  #12680
I've tried to put lead in those slots but I can't get 2 of them in. how did you do it?
Kbmoss is offline
Old 12-17-2011 | 05:23 PM
  #12681
JEFFs SC10's Avatar
I put all of them in, you may have to push hard, they slid in perfectly, but it looks so ghettoriffic. So glad I got that Exotek.
Old 12-17-2011 | 05:25 PM
  #12682
MantisWorx's Avatar
have you driven with the exotech? i have done it both ways and its far from being the same no matter how much weight you add or what braces you add. how did you put weight on the bottom of the chassis? you will not get the same results with lead and braces, its just simply not true. I think the opinion from someone that has had both would be worth something!!!! but what do i know LOL!!
MantisWorx is offline
Old 12-17-2011 | 05:43 PM
  #12683
king revo's Avatar
Default Cool
Originally Posted by jmoneym
Hard pack, geared at 93/16. I like it much better then the MMP Tekin 550 5.5t i was running. I think i'm going to settle on a 540 5.5t.
My opinion 540 for indoor and 550 for outdoors. I think the SC10 is so versatile you can run it with any motor or setup. You cant say that about other SC out there.
Thanks I'm more confident with my intuition of 540 indoor ( especially high bite)and 550 outdoor.. I'm running the 550 tomorrow because I didn't have the proper spur. it's gonna be my first race with the truck and I will test with the 540 during the week.. I did read the posts about shimming inside ball studs and camber link but can you or someone please tell me why I would do this and what to expect if I did.. I'm basically going to be trying to dial truck in as day goes.. Thanks
king revo is offline
Old 12-17-2011 | 06:09 PM
  #12684
I got a settlement from a car accident finally. At the new year, I will purchase this glorified hunk of metal and try it. Then I won't have to listen to experience over physics again.
Old 12-17-2011 | 06:14 PM
  #12685
Stop making excuses , you know you wanted one.
jmoneym is offline
Old 12-17-2011 | 07:23 PM
  #12686
I totally do. It's sexy. I admitted that many moons ago!
My argument is the cost≠performance over my current setup that physics will prove is very very similar (until such a time you are competing with National Drivers where 2-5% matters.)
I keep getting misunderstood as "it's shit. don't waste your money".
Old 12-17-2011 | 07:38 PM
  #12687
I totally agree. If it was priced at $50 i would try it. Not to say it's not worth it. This hobby we love trying new things.
Fact is racers think cause they add parts going to make them faster fact is working on your driving and throttle control does.
I see guys run and get this and that still suck.
jmoneym is offline
Old 12-17-2011 | 07:46 PM
  #12688
Makarrov's Avatar
When I rebuilt the diffs I used two of the shims that go under the sun gear.
Off to start the tear down.
Makarrov is offline
Old 12-17-2011 | 08:05 PM
  #12689
Chad Smith's Avatar
Hey guys, need some setup advice. I need alot more traction. My truck is loose coming out of corners like it is over rotating and also on sweeping turns my truck wants to spin out. It feels like I have to drive this truck like a 2wd buggy right know.
I also think it could be my chassis brace. Does taking away some of the flex have an effect on the traction or handling of the vehicle?
Chad Smith is offline
Old 12-17-2011 | 08:29 PM
  #12690
Chad,
It would help if you can post your setup. That way we can make recommendations on what you're currently using.
Mark
munrath is offline
