Like Tree5Likes
SC10 4x4 Thread
Old 12-05-2011 | 03:46 PM
  #11926
symmetricon's Avatar
Originally Posted by Dano628
Thanks . What hole are you using ?
The second from the front.
symmetricon is offline
Old 12-05-2011 | 03:49 PM
  #11927
CraigMBA's Avatar
Originally Posted by special_k
I need new A-arms for the front and I wood like to know what u guys wood get the stock ones or the RPMs or if there is another op?
I've had both. Both of them warp, the RPM ones way quicker. FWIW from now on I store my truck with the shocks disconnected, but I haven't been doing it long enough to say if that fixes the problem or not.
Somebody posted a picture of the RPM arms that had broken a couple of weeks back. I've never seen or heard of anyone busting a stock one.
CraigMBA is offline
Old 12-05-2011 | 04:04 PM
  #11928
anyone ran the tekin pro4 yet in the trucks? what pinion gear to run with the 4000kv?
iburnnitro is offline
Old 12-05-2011 | 04:15 PM
  #11929
I run a 15 or 16 tooth pinion with the stock spur and the 4000kv pro4.
Krio is offline
Old 12-05-2011 | 04:16 PM
  #11930
that was me who broke the arm...
The stock a arms dont break, the just bend/bow
The rpm arms can bend... with some nast hits, which I am fully capable of
they seem to ben at the inner hinge pin if the do bend at all. the a arm I broke got bent from casing and hooking the jump with the rear a arm, it bent, i heated it up and bent it back, then it broke hitting a steel upright i-beam.
all in all the rpm arms are stiffer and perform better imo.
Old 12-05-2011 | 04:47 PM
  #11931
Chad Smith's Avatar
Just bought a new 4x4 just to have a new kit even though it isnt new for long.
Quick question. Under the setup sheets in the back of the manual under "standard setup" which I am assuming is the kit setup of what we put on it while we are building the truck. It says 5k rear and 20k front diff oil is this accurate? I will still open them up to make sure there is enough fluid in them but wanted to know if that is really whats in the diffs. Also another question since my diffs are still new no runs on them and there is no wobbly outdrives should I still put more shims inside of the diff to help prevent it in the near future?
Chad Smith is offline
Old 12-05-2011 | 06:35 PM
  #11932
blakelenk521's Avatar
hey guys,
newbie question but in the sc10 4x4 can i mix shock oils to get something in between like could i mix 35 weight and 30 weight to get 32.5 weight ? already have those fluids and seeing if i could save a quick buck. if not thats fine too
blakelenk521 is offline
Old 12-05-2011 | 06:46 PM
  #11933
nmdesertracer's Avatar
Originally Posted by blakelenk521
hey guys,
yes just put 50/50!
nmdesertracer is offline
Old 12-05-2011 | 07:03 PM
  #11934
hey guys,
Roughly yes but a little more in depth than that.
http://www.scriptasylum.com/rc_speed/oil_mixer.html
bohdi is offline
Old 12-05-2011 | 07:06 PM
  #11935
IRM616's Avatar
16 is good
IRM616 is offline
Old 12-05-2011 | 07:11 PM
  #11936
SkarTisu's Avatar
hey guys,
In that case mentioned above, yes it will work for current Associated oils.
It won't work that way in all cases for all oils from all manufacturers though. To know for sure, find out the cst rating for the oils you're using. "Weight" ratings for oils are specific to each manufacturer. "cst" rating is an absolute value of the oil viscosity regardless of manufacturer.
SkarTisu is offline
Old 12-05-2011 | 07:12 PM
  #11937
CoyoteSlash's Avatar
I got a crazy question: I just got in a FT shocks for the front and it didnt come with any o-ring so I could do up my shocks emulsion style. Just the bladders why is this? When u can have a chose bewteen the 2 with the stock shocks. So I kinda modified the stock bladders to o-rings and they work 4 me better.
Originally Posted by n8b
I didn't get the o-rings either. I e-mailed customer service with no response. Suppose I need to make a phone call.
They do not come with them. They are setup for a Bladder build. Emulsion is a choice and you need to purchase This Item to gain that option. The FT shocks aren't supposed to come with them. Check the picture of the kit laid out for visual proof.
They also do not come with the Shock Bushings if you needed/were thinking you got those too.
FYI! =D
CoyoteSlash is offline
Old 12-05-2011 | 07:20 PM
  #11938
n8b
FYI! =D
Copy that, I was told they came in the kit. Shame on me. Thanks coyote!
n8b is offline
Old 12-05-2011 | 07:25 PM
  #11939
FYI! =D
I recently assembled my kit and it came with bladders and the rings. You may want to contact AE to check.
Kbmoss is offline
Old 12-05-2011 | 07:26 PM
  #11940
No no. They got the FT shock upgrades. The TRUCK KIT comes with emulsion. Yes. That's not what's being questioned.
